MK4S and Ghosting in structural profile
Scott
(@scott-18)
I'm having real trouble to get clean prints with my MK4S, as I get ghosting in every prints in structural profile, on both axis.
It's a printer that I built in kit, and I triple checked every step (I already built a MK3s and a MK4 so I'm used to building).
Here are all what I tried to reduce it:
  • Belts: I checked belt alignments many time to be sure there are not rubbing anywhere (I changed Y motor mount to well centered belts on pulley)
  • Tensionning: I tried all tension on each belts ("just right", too tight or too lose, with the Prusa app AND G2 belt tension print test)
  • Input Shaper: I changed IS value with Prusa Accelerometer and according to a test print. Both gave me different values, but none solved the issue.
  • Filament: I tried with PLA (Generic profile), PETG (generic profile), Prusament PETG (Prusament PETG profile AND generic PETG profile)
  • Flow: I tried to change flow to be sure it was not too high
  • Speed: I tried to reduce print speed, reduce acceleration and of course ghosting was less visible, but I didn't buy MK4S to print at 10mm/s print and 1000mm²/s acceleration...
  • Temperature: I changed filament temperature to try to tune it
  • Rods and Bearings: I tried to switch rods and bearings from standard ones to Misumi
  • Nextruder: I tried different screw tensions (I calibrated each time)
  • Nozzle: I tried to switch from HF nozzle to a regular one
All that steps didn't show any improvement.
I contact Prusa Support, they checked everything I already checked and after 1 hour they just told me that they can't find issue and they have to discuss internally with their team.
I don't have any news news since a week, and I'm considering returning the printer as I can't get quality print as I should.
Does anyone have another input/idea before I send printer back?
Thanks a lot, I will show some prints as soon as I can.
Respondido : 26/09/2024 8:12 am
Scott
(@scott-18)
RE: MK4S and Ghosting in structural profile
Respondido : 26/09/2024 8:23 am
Trance
(@trance)
Same issues here, although my first prusa kit (MK3S+ to MK4S) I followed the build guide perfectly. I have built a voron in the past and tuned several ender3's and MK3S's. Structural profile just produces worse prints than speed setting for me. I'm still having vfa and artifacts in speed as well but the are less pronounced. I was thinking input shaper values but my XL sitting next to it prints beautifully.
Respondido : 29/09/2024 10:01 pm
Do other profiles print cleanly?
Respondido : 30/09/2024 8:50 am
