Keep getting a filament stuck message on my MK4S
Seite 5 / 6
LarGriff
(@largriff)
RE: Keep getting a filament stuck message on my MK4S
Posted by: @chris-purves
Well the stuck filament didn't help ... seems like the nozzle is somehow ripping up what its already printed.
This looks like Z-offset is too low.  Try setting Z-offset in PrusaSlicer to +0.04 .  Or manually raise it with LiveOffset by holding the button till it beeps, then raise it to +0.04 .
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Veröffentlicht : 27/03/2025 2:38 pm
Nokar ProtoFab
(@nokar-protofab)
This is a far bigger issue than Z offset sadly.
Veröffentlicht : 27/03/2025 3:03 pm
Bobster
(@bobster)
Posted by: @faraz
I moved from an MK3S+ to an MK4S a few weeks ago, and have been having this issue from the beginning. Every print at some point pauses with the message that filament is stuck. I then have to do an unload (which happens normally) do a load (which also happens fine), and then continue with the printing. This happens both with PETG as well as PLA filaments (both Prusa filaments), and both 0.4mm as well as 0.25mm nozzles.  Any ideas on what might be causing this?
Thanks
Hi, I have been having this problem just lately. I would tell it to unload filament, then reload filament and I would manually push filament from the cassette down to the nozzle and it would load ok and go on printing then stop again and I would have to repeat the process. I changed the PTFE tube and have not had any problems since. It might be worth a try.
Veröffentlicht : 30/03/2025 6:09 pm
alias23b
(@alias23b)
I have an ongoing conversation with support on this issue.
In the latest round of troubleshooting, I found that the stuck filament error does not occur when my enclosure doors are open.
I'm curious.  Is anyone else running into the issue without an enclosure, or with the doors open?  Or, is everyone else that is running into the repeating stuck filament errors have an enclosure with the doors closed?
Veröffentlicht : 07/04/2025 6:06 am
If you are printing PLA in an enclosure, the temperature can rise and cause poor cooling of the extruder heatsink, this can allow the filament above the heat break, to expand inside the tubing, and cause a blockage
in the image above the Green area should be kept cool by the hot end cooling fan. and the area inside the the red ring, is directly heated by the hot end heater. the small section of pipe between the red and green areas, is the heatbreak, it is designed to prevent heat getting into the green area.
If the temperature in the Green area rises significantly due to high ambient temperature, the filament inside can raise above the Glass transition temperature and it can soften, causing the pressure from the extruder drive hobbed gear to expand the diameter of the filament and cause friction within the nozzle tube (this is often referred to as Heat Creep).
I live in England, where we do not have naturally high temperatures, but in the winter, if I use the solid fuel heater, the local temperature can be enough to cause heat creep
countries like america, Australia,  and countries along the equator, can have high ambient temperatures which may cause unexpected heat creep during day time! hours
It is important to also check for dust collection on the extruder heat sink to minimise issues.
Veröffentlicht : 07/04/2025 10:45 am
Bobster
(@bobster)
Hi Joan, thanks for the comprehensive reply, I too live in the UK and have my printer in a homemade enclosure in an outside workshop. I have a mini heater in the enclosure for winter use and I agree with you that it sometimes gets a bit warm and it never occurs when I have the door open. I will have to keep a better eye on the temperature from now on. It seems so simple when it's explained. Thanks again, Bob.
Veröffentlicht : 08/04/2025 4:17 pm
pink_clown
(@pink_clown)
Guys, there are several threads with the same/similar issue. So let me repeat my post:
Let us differentiate between the filament stuck, when no filament extruded and the filament stuck error appearing on the screen.
1. The filament stuck error is based on the loadcell filament push force monitoring so when you switch it off via the settings menu, the error should not appear. The stuck error could be recognized also at the moment the insufficient nozzle temperature, the filament pushes on the loadcell too much, which leads to filament stuck error. It does not need to be necessarily followed by a real filament stuck.
2. the real filament stuck (filament extrusion stops) could be caused by lower than required nozzle temperature. Be aware sometimes the nozzle purge temperature could be different (set in FW) than the printing temperature (set by slicer)  so the nozzle is not heated enough. Secondary effect of this is a dent on the filament at the extruder gear position and a clicking sound.
3. Sometimes the Filament stuck error can be a false warning, sometimes can be real. I guess the FW team still should refine this function.
Note:
Printing in the case especially PLA or PETG can lead to the filament preheating before it enters the extruder gear. This moment the filament between the extruder gear and the idler is not solid enough and the gear clicks creating a dent on the filament surface.
The low  idler force against the extruder gear can also lead to clicking and dent generation.
The case is to print warping stuff like ABS, PC , ASA etc.  Do not close the case while printing PLA, PETG, PWB.
Veröffentlicht : 15/04/2025 5:07 pm
alias23b
(@alias23b)
@pink_clown,
  • The issue never existed for me before the mk4 => mk4s upgrade.
  • It is the actual filament stuck with clicking issue
  • I print with PETG
  • Opening the enclosure reduces but does not eliminate the issue.
I agree it is a preheating issue.  unfortunately the change that caused this came with the mk4s upgrade or related firmware updates.  It will need to be rolled back or fixed.  My guess is a change was made for the higher feed rates is the root cause.
Veröffentlicht : 15/04/2025 5:57 pm
pink_clown
(@pink_clown)
Try a bit temperature fidling with temperature and compare the filament profiles of MK4 and MK4S, sometimes they do not match. Sometimes tihgting the extruder idler spring screws can help, so the force of the idler bearing against the extruder gear will be stronger.
The higher feed rate requiers higher nozzle temperature which can cause a filament preheating before the extruder entrance, it becomes softer and the problem is just there.
Posted by: @alias23b
@pink_clown,
  • I print with PETG
Veröffentlicht : 16/04/2025 2:02 pm
gooner
(@gooner)
Ditto!!
Veröffentlicht : 16/04/2025 2:22 pm
Sembazuru
(@sembazuru)
My apologies for not re-reading the previous 4 pages of posts... My question, below, may already be answered and I didn't bother to check.
@pink_clown,
  • I print with PETG
Are you sure that you are using the high-flow nozzle that came with your MK4S upgrade kit, and/or using the correct printer profile for high-flow or standard flow nozzle (depending on which you have actually installed on your printer)? If you are accidentally using a high-flow profile with a standard flow nozzle you may be slicing with too high of a max volumetric flow. Prusa does provide both high-flow and standard flow printer profiles for the MK4S (I have both enabled in the configuration wizard because I use both nozzle types).
See my (limited) designs on:
Veröffentlicht : 16/04/2025 4:04 pm
Bobster
(@bobster)
Hi All, Joan's answer has cured my sticking filament problem, the filament had swelled in the ptfe tube due to my enclosure getting too hot. As I pulled it out of the tube I had to pull very hard to remove it, I cut it off and inserted fresh off the reel and it slid in very easily, so the filament had swollen. Now I try to keep the temperature no higher than 26 - 27 degrees and I have had no further issues of it sticking with pet or pla. Thanks again Joan.
Veröffentlicht : 16/04/2025 5:00 pm
3 weiteren Personen gefällt das
alias23b
(@alias23b)
Thanks @pink_clown, I already tried temp changes and the extruder idler spring screws both ways, that didn't help. The high flow nozzle was giving me such poor quality prints, I reverted to a low flow nozzel (tried 3 different nozzles with no difference), printer profile in Prusa Slicer is Low flow MK4s, and the setting on the printer is set to the low flow nozzle too. I did all of that a couple of months ago.
I haven't tried the settings compare. That is a new suggestion. There's a lot there, so I'll give that a go the next time I run something.
Posted by: @pink_clown
@pink_clown,
  • I print with PETG
Veröffentlicht : 17/04/2025 3:49 am
alias23b
(@alias23b)
On the advice of Prusa Support I reverted to the low flow nozzle a couple of months ago (I've tried 3 different nozzles with no difference in result). The printer profile in Prusa Slicer is Low flow, and the setting on the printer is set to the low flow nozzle too.
Posted by: @sembazuru
@pink_clown,
  • I print with PETG
alias23b
(@alias23b)
 @pink_clown, the filament profiles did have some differences.  I had originally saved the default MK4 settings off with different colors and was still using those filament profiles.    I reverted the filament profile to the current default for the MK4s and ran a test print with the doors closed.  It failed right away, twice.  I appreciate the new idea, unfortunately it appears to have made no difference for me
@pink_clown,
  • I print with PETG
Veröffentlicht : 18/04/2025 5:44 am
davsan
(@davsan)
Mitglied
I had the "filament stuck" error constantly when printing a big PC Blend model but it was definitely due to warping. After I clamped the PEI sheet onto the bed and began again from scratch, the error never came back ...
Veröffentlicht : 18/04/2025 6:57 pm
Roy
 Roy
(@roy-4)
Mitglied
Posted by: @nokar-protofab
Tighten the 6 screws on the back of the extruder 1/4-1/2 turn, I am officially no longer getting a filament stuck and homing issues in the air when trying to return Z to home.
Thanks, I think this solved the problem for me.
Like others in this thread, the "filament stuck" problem started after a Mk4 to Mk4S upgrade including the high flow nozzle and appropriate new printer setting in PrusaSlicer.  At first the printed worked great but after about one roll total of filament (various parts in PLA and PETG) it started giving the error, first with PLA and then with  both PLA and PETG.
The screws on the back of my extruder were surprisingly loose.  Maybe I missed a step in the Mk4S upgrade instructions, or perhaps the instructions could be updated to check these.
So far I've printed maybe 100g of PLA with no issues whereas most recently I couldn't run the printer for more than a minute or two before the stuck filament error.
Veröffentlicht : 17/05/2025 10:43 pm
Mikkel
(@mikkel)
Mitglied
Wow, actually looks like this fixed my issue as well. I could never finish a print with PETG and the High-flow nozzle before. I had one issue after tightening the screws, but after adjusting the temperature to the recommended max for my PETG filament I had zero issues after that. Thank you for the advice! Had given up on my HF-nozzle until I saw this suggestion.
Veröffentlicht : 24/07/2025 11:50 am
James
(@james-36)
Mitglied
Solved for me!  I just had this same problem on a 3 to 4S upgrade.  The build went fine and all the tests passed.  First print - filament stuck error the instant gets to point starts the print.  Again and again - cannot print any of first layer.  I tried someones comment about increase idler tension also failed.
Whats solved for me was to reduce the tension on the filament idler lock.  The build instructions say set the long screws equal with the face of the swivel part.  I moved about 3 turns loser and then see no error.  Somebodies comment about the stepper motor made me think of this: too much tension on the filament idler and that could create enough drag to appear same as if filament was stuck.
Veröffentlicht : 01/09/2025 12:19 am
Tom
 Tom
(@tom-43)
Mitglied
For those people that need a quick fix:
It mostly happens when you do a bigger print, which implies that the speed of the filament intake cannot keep up with the outflow... not sure if that's true but that's my theory if I then set the print speed to 70% the printing continues like normal; yet a bit slower... saves me a lot of time in the end, and is a neat workaround... hope it helps others as well?!
Veröffentlicht : 16/10/2025 10:54 am
Seite 5 / 6
