					                		IP address setting - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/ip-address-setting/</link>
                <lastBuildDate>Mon, 15 Jun 2026 21:03:36 +0000</lastBuildDate>
                        <title>RE: IP address setting</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/ip-address-setting/#post-793852</link>
                        <pubDate>Fri, 05 Jun 2026 09:17:10 +0000</pubDate>
                        <description><![CDATA[What device do you have as router? btw this is the way that routing should be. Never go for static ip on your devices, only on the routers you assign them to your devices. So you have a cent...]]></description>
                        <content:encoded><![CDATA[<p>What device do you have as router? <br />btw this is the way that routing should be. Never go for static ip on your devices, only on the routers you assign them to your devices. So you have a central point where to admin them. If you ever change ip ranges you will have one point to arrange it instead to have to go to each device and assign it on it.</p><blockquote data-userid="556183" data-postid="793717" data-mention="zburget"><div class="wpforo-post-quote-author"><strong> Posted by: @zburget </strong></div><p>ssmith: Thanks! Configuration file as the only way - huh, I really didn't think of that. I've never seen that with any network device.</p></blockquote><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>3d0zer</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/ip-address-setting/#post-793852</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/ip-address-setting/#post-793851</link>
                        <pubDate>Fri, 05 Jun 2026 09:15:34 +0000</pubDate>
                        <description><![CDATA[Yes, and every good router let&#039;s you set static ip&#039;s for devices on the router while leaving dhcp active for other devices. You reserve best a range of ip&#039;s for static ip&#039;s and the rest can ...]]></description>
                        <content:encoded><![CDATA[<p>Yes, and every good router let's you set static ip's for devices on the router while leaving dhcp active for other devices. You reserve best a range of ip's for static ip's and the rest can be dynamic. </p><blockquote data-userid="556183" data-postid="793716" data-mention="zburget"><div class="wpforo-post-quote-author"><strong> Posted by: @zburget </strong></div><p> </p><blockquote data-userid="615416" data-postid="793698" data-mention="3d0zer"><div class="wpforo-post-quote-author"><strong> Posted by: @3d0zer </strong></div><p>Static ip adresses should be set on your router, via dhcp and there you should assign a static ip…</p></blockquote><p>DHCP = DYNAMIC host configuration protocol ≠ static!!!</p></blockquote><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/ip-address-setting/#post-793851</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/ip-address-setting/#post-793717</link>
                        <pubDate>Wed, 03 Jun 2026 23:50:59 +0000</pubDate>
                        <description><![CDATA[ssmith: Thanks! Configuration file as the only way - huh, I really didn&#039;t think of that. I&#039;ve never seen that with any network device.]]></description>
                        <content:encoded><![CDATA[<p>ssmith: Thanks! Configuration file as the only way - huh, I really didn't think of that. I've never seen that with any network device.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Zburget</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/ip-address-setting/#post-793717</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/ip-address-setting/#post-793716</link>
                        <pubDate>Wed, 03 Jun 2026 23:48:05 +0000</pubDate>
                        <description><![CDATA[Posted by: @3d0zer Static ip adresses should be set on your router, via dhcp and there you should assign a static ip…DHCP = DYNAMIC host configuration protocol ≠ static!!!]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="615416" data-postid="793698" data-mention="3d0zer"><div class="wpforo-post-quote-author"><strong> Posted by: @3d0zer </strong></div><p>Static ip adresses should be set on your router, via dhcp and there you should assign a static ip…</p></blockquote><p>DHCP = DYNAMIC host configuration protocol ≠ static!!!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/ip-address-setting/#post-793716</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/ip-address-setting/#post-793698</link>
                        <pubDate>Wed, 03 Jun 2026 18:33:32 +0000</pubDate>
                        <description><![CDATA[Static ip adresses should be set on your router, via dhcp and there you should assign a static ip. That is the best way, better then doing it on your printer.]]></description>
                        <content:encoded><![CDATA[<p>Static ip adresses should be set on your router, via dhcp and there you should assign a static ip. That is the best way, better then doing it on your printer. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/ip-address-setting/#post-793698</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/ip-address-setting/#post-793686</link>
                        <pubDate>Wed, 03 Jun 2026 16:40:48 +0000</pubDate>
                        <description><![CDATA[How to set a Static IP Address from Prusa&#039;s support pages...?
... it&#039;s not heresy, or I&#039;m as guilty as you 😀]]></description>
                        <content:encoded><![CDATA[<p><a href="https://help.prusa3d.com/article/how-to-set-a-static-ip-address_695648" target="_blank" rel="noopener">How to set a Static IP Address</a> from Prusa's support pages...?</p>
<p>... it's not heresy, or I'm as guilty as you 😀 </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>ssmith</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/ip-address-setting/#post-793686</guid>
                        <title>IP address setting</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/ip-address-setting/#post-793658</link>
                        <pubDate>Wed, 03 Jun 2026 12:06:35 +0000</pubDate>
                        <description><![CDATA[I have one heretical question: How can I set a static IPv4 address on the Ethernet port? If I use DHCP, the address is assigned. If I set a static address, the IP stack settings disappear an...]]></description>
                        <content:encoded><![CDATA[<p>I have one heretical question: How can I set a static IPv4 address on the Ethernet port? If I use DHCP, the address is assigned. If I set a static address, the IP stack settings disappear and there is no way to set it. Or at least I haven't found a way to do it. Firmware 6.5.3 If this has been discussed here somewhere or there is a guide for it, then I'm sorry, I couldn't find it.</p><p>Best regards</p><p>Zbyněk</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-hardware-firmware-and-software-help/ip-address-setting/#post-793658</guid>
