How to clear error statistics in MK4?
miroslav.h4
(@miroslav-h4)
As we know, the printer calculates errors (both distances traveled by individual axes, filament consumption, etc.) Then there are filament loading errors. and after a certain number it will issue a warning. But these mistakes after a certain time, especially when using MMUs, are plentiful. But this warning is pretty annoying, but without a solution. What good is it to me that I checked the relevant part according to the recommendations if I can't tell the printer, and if everything is OK, reset the counter to zero. So far, I've solved it by resetting it to factory settings, but I'll lose all settings and other statistics in the printer. So I ask if anyone knows how to do it and reset the counters, or did I overlook something somewhere?
Posted : 13/10/2024 8:31 am
JP Guitars
(@jp-guitars)
There is a menu item on the printer to clear the annoying filament load error message, I've used it in the past. However, I cannot find it at present, it may only show when relevant.
Posted : 13/10/2024 9:06 am
miroslav.h4
(@miroslav-h4)
RE: How to clear error statistics in MK4?
Hopefully it will be useful for others as well: After asking technical support, the option to remove the annoying message was found: Hardware -> Nextruder maintenance. This tells the printer that everything has been checked, or defective parts have been replaced, and the notification is no longer needed.
Posted : 15/10/2024 9:33 pm
