Heat test fails new MK4s
Brand new factory assembled MK4S fails calibration heat test, would this not be tested before shipping?
any help to correct this would be appreciated
Angus
Opublikowany : 26/12/2024 3:32 am
RE: Heat test fails new MK4s
There should be a paperprintout that you received with the printer showing it passed all tests as well as a small Prusa emblem print.
It's possible something happened during shipping, hence the reason you have to rerun all the tests after setup.
Best bet it to contact support.
Opublikowany : 26/12/2024 3:58 am
Topic starter
answered:
No test results other than the key chain on the print bed, the unit prints fine just comes up with a message every time to complete calibration.
I’ll check with tech support, thanks for the reply
Opublikowany : 26/12/2024 4:04 am
