Heat test fails new MK4s
Angus
(@angus)
Brand new factory assembled MK4S fails calibration heat test, would this not be tested before shipping?
any help to correct this would be appreciated
Angus
Posted : 26/12/2024 3:32 am
Brian
(@brian-12)
RE: Heat test fails new MK4s
There should be a paperprintout that you received with the printer showing it passed all tests as well as a small Prusa emblem print.
It's possible something happened during shipping, hence the reason you have to rerun all the tests after setup.
Best bet it to contact support.
Posted : 26/12/2024 3:58 am
Angus
(@angus)
No test results other than the key chain on the print bed, the unit prints fine just comes up with a message every time to complete calibration.
I’ll check with tech support, thanks for the reply
Posted : 26/12/2024 4:04 am
