Filament 'stuck', but not really after latest 6.4.0
Danut Tabacaru
(@danut-tabacaru)
Membre
Hi All,
The latest firmware introduced this auto retract feature.
Seemed weird to me at first, and still not sure if I want it enabled by default, but i left it on to see if how I'd feel about it after some time.
However, ever since it starting doing this maneuver , occasionally (maybe 1/5 prints) will report 'filament stuck' right after the print starts and the first line is extruded to prime the extruder.
The filament is NOT stuck... I simply click on unload/load and it loads it automatically without me doing anything. It was clearly not stuck because it extruded that first line without issue...
Seems like a firmware issue?
Publié : 10/12/2025 4:59 pm
1 personnes ont aimé
LarGriff
(@largriff)
https://forum.prusa3d.com/forum/postid/773033/
This problem, and others, with firmware version 6.4.0. has been reported by numerous people.  Most have reverted to firmware 6.2.6.  Prusa is not what it used to be.
Ce message a été modifié il y a 5 months par LarGriff
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Publié : 11/12/2025 2:12 pm
Danut Tabacaru
(@danut-tabacaru)
Membre
RE: Filament 'stuck', but not really after latest 6.4.0
Thanks for the reply, I didn't know it was so wide-spread (I tried a search but nothing showed up).
From quickly browsing the thread, I am a bit relieved that others have the same issue (so likely not a hardware fault on my end).
I have also run into the issue you mentioned - waiting for reloading filament mid print. I have had this issue before with older firmwares, but the issue manifested itself exactly 2 times in an entire year. On 6.4.0, this same reload filament issue happened to me twice on the same print! (I ended up abandoning that print.)
I am unsure if I will revert back to an older FW version just yet.
From reading the thread you linked, I have a feeling the bugs are to do some incompatibilities with saved configurations from older firmwares.
I re-did my filament sensor calibration like 3 times (it seemed flaky, occasionally not detecting the filament) and for now... everything seems to be back to working order in 6.4.0. (I am expecting another issue to show up eventually though)
Publié : 11/12/2025 4:28 pm
Danut Tabacaru
(@danut-tabacaru)
Membre
Well, filament sensor re-calibration did not fix the issue.
I even cleaned out the entire gearbox assembly, and still, I get "stuck filament" after the first line for priming the extruder.
I'm back on 6.2.6 until it gets fixed.
Publié : 11/12/2025 11:06 pm
dracolorium
(@dracolorium)
Posted by: @danut-tabacaru
That's exactly the same behaviour we had with our four printers. The message appeared after the purge line. Always. Since we went back to 6.2.6, everything has been working perfectly again.
Publié : 12/12/2025 7:43 am
Petr
 Petr
(@petr-9)
Membre
Same problem with both MK4S I have, it started in RC version, just hit reset and start print again, you do not need to unload and load. It seems like bug, I revert back to lower FW too.
Publié : 20/12/2025 11:21 am
quazimoto
(@quazimoto)
Membre
This happens on every print for me on my MK3.9s. It's never had a filament jam before, but after 6.4.0 it's happening all the time. I thought the filament retractions was a pretty cool idea to stop oozing, but it looks like just retracts way too far and it oozes out of the nozzle anyway, so not sure what the purpose of this is. Anyways, reverted to 6.2.6.
Publié : 12/01/2026 5:24 am
up_and_adam
(@up_and_adam)
I'm seeing the same thing; first time I saw it was loading PLA after having printed PETG, so I thought it was struggling to purge the PETG at PLA temperatures and just needed more purging, but I've seen it in several prints now.  I guess it's time to learn how to downgrade firmware, on my brand new machine.  What an excellent experience this thousand dollar printer has been so far, there was definitely a reason to pay 3 times what a Bambu costs for this.
Publié : 20/01/2026 2:48 am
Cornelius Grimm
(@cornelius-grimm)
Membre
I have the same issue since the 6.4.0 firmware update (MK4S). One out of two or three prints will stop after purging in the front left with the filament stuck warning. After the unload/load procedure it prints just fine. I never had an issue with stuck filament before the firmware update.
I disabled the auto-retract feature, but it does not help.
Please, Prusa, fix this... 🙂
Publié : 15/02/2026 10:09 am
dracolorium
(@dracolorium)
Had a similar behavior with my machines. After the purge line, this filament stuck message came up. Just go back to 6.2.6 and continue working 🙂
Publié : 16/02/2026 6:31 pm
citsejam
(@citsejam)
Seems I'm part of the "filament stuck" crew...
I upgraded from 6.2.6 to latest 6.5.3 and obviously nothing was fixed - looks I need to downgrade too 🙁
Btw, it is easier to just reset the printer and start the print again instead of "unstucking" the non-stuck filament
Publié : 03/05/2026 7:43 pm
dracolorium
(@dracolorium)
There have been no information about this problem in the release notes. Therefore I did not even try to update any printer, with 6.2.6 they are running fine.
Ce message a été modifié il y a 4 days par dracolorium
Publié : 04/05/2026 11:25 am
Petr
 Petr
(@petr-9)
Membre
No fix yet. It is half year and no fix. I already upgraded and I am doing reset in 8 from 10 prints.
Publié : 04/05/2026 3:54 pm
