constant filament loading errors (while there are no filament loading errors!)
wolph42
(@wolph42)
So,
A few days ago it took me 4 or 5 times to figure out that the 'filament loading error' was not in the nextruder but in the attached mmu (this really is unclear, would be nice if Prusa can make more clear error messages). Anyhoot, fixed the issue with the mmu and evertyhing was peaches...however now after every finished print I get a the following error message: 'printer has detected multiple consecutive loading error. etc. etc.'. Resetting, turning it off and on does not work. So how do I get rid of this message?
edit: in case its not entirely clear: the error message is about the MMU not the nextruder. If I turn off the MMU i don't get the error message.
This topic was modified 9 months temu by wolph42
Opublikowany : 09/09/2024 12:36 pm
RE: constant filament loading errors (while there are no filament loading errors!)
Don't have a Mk4 or MMU but according to this github entry https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4113#issuecomment-2270681113 there is a menu item to reset the status.
Opublikowany : 09/09/2024 5:08 pm
wolph42
(@wolph42)
thanks, ill investigate that!
Opublikowany : 09/09/2024 9:12 pm
