Cannot find MK4S profiles in Prusaslicer 2.8.0
Upgraded my MK4 to MK4S today. Flashed it to 6.1.3, and set printer to MK4S.
But now I cannot find the profile for MK4S in Prusasliser, and hence the printer will not print, because it comes from the wrong profile version...
Have tried multiple times to check for configuration updates.
Any suggestions??
RE: Cannot find MK4S profiles in Prusaslicer 2.8.0
You have to install the MK4S like a new printer via the "Configuration Wizard". After this, the new profiles will be available.
Thanks, now I am fine 🙂
There is no "Input Shaper" in the profile names, do you know if "Input Shaping" is on by default in this profiles?
What would make you think that Input Shaper is not active in these profiles? 🙂
FYI: the non-Input Shaper profiles can now be found at the end of the list under "Legacy profiles Family". So Input Shaper is the new normal now. 🙂
To use the old ones you'll have to create another "Physical printer" with these profiles.
