Bad first layer print bed end
Speedythebee
(@speedythebee)
Hi my MK4s making me headache.
i printed 5 pieces of the multiboard core items. All worked. But now the problem accourd that the nozzle is to high at the end of the print bed.
For multiboard the first layer lines are very thin. I’m able to see that in the middle all is fine and at the end of the bed it’s to high. Filament is round in first layer and don’t stuck at bed. It’s like to high manually adjusting at the old mk3s tutorial. Tested different filament and different print beds. I also see that when the bed is leveling sometimes its correcting position little bit and test again. In this area it seams that there ist to high bad first layer. Any idea what causes this?
thank you
Este debate ha sido modificado el hace 7 months 2 veces por Speedythebee
Respondido : 21/10/2025 3:20 pm
Speedythebee
(@speedythebee)
Tested satin and normal plate. Cleaned it well. Always the same. First layer to high. If i print in the middle of the bed it worked.
Esta publicación ha sido modificada el hace 6 months por Speedythebee
Respondido : 22/10/2025 6:04 am
