Z Axis position
Hello I have a problem using the MK4, 99% of times it loose the Z Axis position; I try to explain better, if I use always the same filament there is no problem, if I change filament ZAxis rise the extruder, then quite often it start printing from the rised position thinking it is the zero point, any suggestions?? Thanks all
Posted : 27/10/2025 9:29 am
