Upgrade MK4 - MK4S
Hello, at the weekend I upgraded to MK4s which was no problem so far.I wanted to print one of my files and then I got the following error message
- The G-code is not fully compatible
- Print model does not match
I had changed the printer model to MK4S (I saw that the Hostname is still MK4) - Speed of the fan will be reduced
But I was still able to print.
The new Firmware is installed
May you have some ideas?
Thank you for your help (I checked the error message on the web page, found nothing.
Publié : 09/12/2024 7:02 am
RE: Upgrade MK4 - MK4S
Have you changed MK4 to MK4S in the printer hardware menu?
Publié : 16/12/2024 1:04 pm
1 personnes ont aimé
Had do you sliced your files again with the prusaslicer?
Had do you upgraded prusalicer profiles adding mk4s profiles?, check that you have to choose also if you're using standard nozzle or CHF (high flow) nozzle.
Regards
Publié : 21/12/2024 3:43 am
