					                		Gcode not compatible error - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/gcode-not-compatible-error/</link>
                <lastBuildDate>Wed, 10 Jun 2026 18:47:02 +0000</lastBuildDate>
                        <title>RE: Gcode not compatible error</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/gcode-not-compatible-error/#post-772377</link>
                        <pubDate>Mon, 01 Dec 2025 15:38:24 +0000</pubDate>
                        <description><![CDATA[Hopefully this saves time for someone who is in a similar situtation as I was. I have the MK4S with mmu3. The issue I had was that the mmu3 unit somehow got disabled in settings. I had to re...]]></description>
                        <content:encoded><![CDATA[Hopefully this saves time for someone who is in a similar situtation as I was. I have the MK4S with mmu3. The issue I had was that the mmu3 unit somehow got disabled in settings. I had to reenable by Settings &gt; MMU Unit (toggle to enabled), and everything worked fine. 
Unfortunately before I thought to check that, I followed some weird rabbit holes.]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>nfa-prusa</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/gcode-not-compatible-error/#post-772377</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/gcode-not-compatible-error/#post-747486</link>
                        <pubDate>Sun, 27 Apr 2025 12:16:58 +0000</pubDate>
                        <description><![CDATA[You&#039;re not alone — I&#039;ve seen a few people mention the same issue after upgrading. It’s odd when it prints fine but still throws up warnings; definitely feels like something minor between sli...]]></description>
                        <content:encoded><![CDATA[<p>You're not alone — I've seen a few people mention the same issue after upgrading. It’s odd when it prints fine but still throws up warnings; definitely feels like something minor between slicer settings and firmware versions.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>avrorafrix</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/gcode-not-compatible-error/#post-747486</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/gcode-not-compatible-error/#post-746167</link>
                        <pubDate>Thu, 17 Apr 2025 09:55:56 +0000</pubDate>
                        <description><![CDATA[I only just had this error, your solution worked first time. Thankyou.]]></description>
                        <content:encoded><![CDATA[<p>I only just had this error, your solution worked first time. Thankyou.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Bobster</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/gcode-not-compatible-error/#post-746167</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/gcode-not-compatible-error/#post-722981</link>
                        <pubDate>Thu, 26 Sep 2024 22:26:13 +0000</pubDate>
                        <description><![CDATA[Thanks to all for the tips currently away from “farm” will have a delve into the firmware when I return]]></description>
                        <content:encoded><![CDATA[<p>Thanks to all for the tips currently away from “farm” will have a delve into the firmware when I return</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>3dtony</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/gcode-not-compatible-error/#post-722981</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/gcode-not-compatible-error/#post-722978</link>
                        <pubDate>Thu, 26 Sep 2024 21:02:46 +0000</pubDate>
                        <description><![CDATA[It&#039;s quite simple and caused by the hardware setting of the Mk4 . you have to change the hardware settings in the printers menu ( not the slicer) from MK4 to Mk4S .]]></description>
                        <content:encoded><![CDATA[<p>It's quite simple and caused by the hardware setting of the Mk4 . you have to change the hardware settings in the printers menu ( not the slicer) from MK4 to Mk4S .</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Studer Austria GmbH</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/gcode-not-compatible-error/#post-722978</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/gcode-not-compatible-error/#post-722000</link>
                        <pubDate>Tue, 17 Sep 2024 13:21:57 +0000</pubDate>
                        <description><![CDATA[I would assume this has to do with the selected printer profile or presets indicating Mk4 when the printer firmware is saying Mk4S.  I would double check all of your slicer settings and make...]]></description>
                        <content:encoded><![CDATA[<p>I would assume this has to do with the selected printer profile or presets indicating Mk4 when the printer firmware is saying Mk4S.  I would double check all of your slicer settings and make sure the presets and names of your physical printer have been updated.  I didn't have a problem when I upgraded mine, but I DID get that message when I tried sending a model from Orca Slicer and assumed it was because there isn't yet an Mk4S profile there and the printer name remains Mk4.  I somewhat wonder if this is a very simplistic printer name check for people with multiple types of Prusa's, and is simply to make sure you're not sending Mk4 jobs to a Mini, for example.  This is just a guess though, as I haven't specifically tested this.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>TeamD3dp</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/gcode-not-compatible-error/#post-722000</guid>
                        <title>Gcode not compatible error</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/gcode-not-compatible-error/#post-721628</link>
                        <pubDate>Fri, 13 Sep 2024 10:14:15 +0000</pubDate>
                        <description><![CDATA[having just finished upggrading to 4s i have had numerous error messages thrown up by prusa slicer and the printer firmware I have managed to clear most of them but cannot get rid of &quot;gcode ...]]></description>
                        <content:encoded><![CDATA[<p>having just finished upggrading to 4s i have had numerous error messages thrown up by prusa slicer and the printer firmware I have managed to clear most of them but cannot get rid of "gcode not comppatible" which seems odd as it was sliced by prusaslicer! If i choose to override the warning and print anyway it prints fine. Has anaybody else this problem?</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/gcode-not-compatible-error/#post-721628</guid>
