Filament change mid-print has 2nd purge as soon as it starts moving to resume print
James
(@james-34)
When have to change/reload the filament mid-print whether planned or not, it purges as normal and I pull off the purged filament. This also happens if I pause the print. As soon as it starts to resume print, it spits out about an inch/3cm of filament while travelling which then gets integrated into the print. I also noticed the XL doing this as well.  Is there a setting in Prusa Slicer causing the issue that I am not seeing? If anyone else has had this issue, have you found a solution or workaround?
Napsal : 03/09/2025 11:32 pm
RE: Filament change mid-print has 2nd purge as soon as it starts moving to resume print
this second purge is design intent, to pressurise the nozzle for the ongoing print process.
when the initial purge occurs, simply hols the waste material with tweezers or long nosed pliers, and the second purge will remain attached to the waste that you are holding, as the nozzle moves back to the model being printed
Napsal : 04/09/2025 9:00 am
