Bearings
zab
 zab
(@zab)
Bearings
I will soon be getting the kit to upgrade my mk3S+ to 4S.  To prepare I've been going through the manual for that upgrade.  I noticed that Prusa is again claiming that the bearings in the kit are pre-lubed from the factory and no additional lubrication is needed.  Given the issues I encountered with the 3S+ kit and it's bearings not actually being lubed, are the bearings now being supplied in the 4S kit properly lubed?
Veröffentlicht : 29/09/2024 4:09 pm
Artur5
(@artur5)
RE: Bearings
 You'll know for sure when the kit arrives. Anyway, get a tube of lubricant ready, I suspect you'll need it.
Veröffentlicht : 29/09/2024 4:50 pm
iftibashir
(@iftibashir)
RE: Bearings
With the full kit you do get a tube of lubricant for applying to the extruder gears - no bearing lubricant tool is supplied however.
Nevertheless, I found that my bearings were VERY well lubricated - a little too lubricated in fact. I had to keep wiping my rods down for a while due to the lube deposits being left on it! You'll probably see it in my build videos - either way, you shouldn't need any at all this time round.
Click here for Original Prusa VIDEO BUILD GUIDES
--> MK4 - MK4S - MINI+ - Accelerometer Guide <--
Veröffentlicht : 29/09/2024 8:09 pm
