X axis motor barely turns on its own
Yenway
(@yenway)
Hi! I've just finished the main assembly process and I'm going through preflight. On the self rest, the x axis failed, and the carriage barely moved. I decided to try to use the position tool to move the x axis as far in one direction as possible, and this was the result. Any idea what I can do to fix this? If I slide the carriage by hand, the pulley turns just fine.
Postato : 01/02/2025 8:15 pm
Yenway
(@yenway)
Here's a video of the phenomenon.
Postato : 01/02/2025 8:29 pm
RE: X axis motor barely turns on its own
Hi
the belt looks loose at the beginning of that clip... ant the motor is trembling, instead of moving
if you take out the three  motor retaining screws. then slip the belt off the toothed wheel, you can try moving just the motor toothed wheel, if it still trembles, the chances are that one of the motor wires is not connected, or the driver may be faulty
Male sure the poser is off before working on the controller.
make sure that all of the pins on the X axis Motor plug are properly inserted and that the plug is correctly inserted into the socket
if the problem persists and if you have a multimeter,  turn off the power, unplug the motor connector and check for continuity between the wires on the motor plug,
there are 4 wires  there should be continuity between the red and blue wires, and continuity between the green and black wires but the green and black wires must not have continuity with the red and blue wires
 Regards Joan
Postato : 01/02/2025 9:39 pm
Yenway
(@yenway)
Even without the belt, it still seems to do nothing but tremble.
I had a look inside, and it looked alright to me. Unfortunately, I do not own a multimeter, but I can try asking friends.
Postato : 01/02/2025 10:35 pm
try swapping the X and Y motor, then try moving axis again, (With the printer switched off...)
if the X motor on the y axis driver, works OK, and the Y Motor on the X axis trembles, then that would point to an X motor  driver fault.
if the X motor trembles on both drivers and the Y motor works on both drivers, then that points to a faulty X motor
Postato : 02/02/2025 12:02 am
I'd get on the chat with Prusa support. Go to their web site, login and look for the chat button. That's why you paid the big bucks for a Prusa printer. For a new machine I would always get on the chat first--to establish any warranty claims— even though I'm pretty sure I could fix things myself.
Given the sorry state of the belt in the video I suspect there's more going on. But the Prusa folks can talk you through dis- and re-assembling the x-axis.
Postato : 02/02/2025 12:11 am
Yenway
(@yenway)
Thanks! It looks like with the cables swapped, the X motor still behaves the same.
FoxRun3D, good idea. I'll reach out to them!
Postato : 02/02/2025 12:15 am
Actually, looking at the video again zoomed in my money is on the grub screws not being properly installed. Looks like the shaft is rotating but the pulley is not moving with it. See https://help.prusa3d.com/guide/3-x-axis-x-carriage-assembly_429986#430910
Postato : 02/02/2025 12:16 am
Yenway
(@yenway)
Just tightened the grub screws again. No luck there yet.
Postato : 02/02/2025 12:51 am
Yenway
(@yenway)
I talked to support and they're sending a new motor my way. I linked them this thread and it was a lot of help. Thanks z ton!
Postato : 02/02/2025 12:36 pm
Good luck.
Joan
Postato : 02/02/2025 3:14 pm
Keep us posted how it goes with the new motor.
Postato : 02/02/2025 3:35 pm
Yenway
(@yenway)
It arrived, and the printer's up and running. Hooray!
Postato : 07/02/2025 5:12 pm
1 persone hanno apprezzato
