mk4s lcd display
Happy
(@happy)
mk4s lcd display
Received a new assembled MK4S mmu3 and lcd screen is very glitchy and goes blank at startup   anyone else have this problem
Publié : 08/10/2024 1:52 pm
iftibashir
(@iftibashir)
RE: mk4s lcd display
Ive had it glitch once, and restarted the printer. Havent seen it since TBH......
Publié : 08/10/2024 2:03 pm
JP Guitars
(@jp-guitars)
Check the cable from the control box to the back of the screen pcb is firmly in place at both ends
Publié : 08/10/2024 2:14 pm
Hesbas
(@hesbas)
I had the same the first time I started a newly build printer. After a few restarts it was gone and did not came back. Using the printer for almost 30 day, daily. It is reliable now. Nevertheless is was a very unexplainable behaviour.
Publié : 08/10/2024 8:48 pm
hervel38
(@hervel38)
Membre
i have the same problem.
i ve check cable, connectique,lcd screen , with the prusa chat, and the solution (for the moment) was to reinstall the firmware with a good usb key
Publié : 20/10/2024 7:09 pm
Michi
(@michi)
I had LCD Problems like to after Upgrade to 6.1.4
But Support said check xLCD cable...
Because I was about to order filament from Prusa anyway, I also ordered a new xLCD cable.
I laid the new xLCD cable from Buddyboard directly to the LCD (MK4S is in the enclosure).
So far I haven't had any problems with the LCD.
But why did my problems start with the 6.1.4 update, or why should the cable suddenly be broken?
Publié : 07/12/2024 3:40 pm
Dyna67
(@dyna67)
Hi Happy,
Did You take a look at the MK4 Assembling and First Prints Troubleshooting forum (Topic "MK4 screen goes blank after some time") ?
Your issue may be the same...
Publié : 08/12/2024 7:59 am
Lobstrosity
(@lobstrosity)
I had the same issue after upgrading from the mk3s to the mk4s. If you can get the LCD to cooperate once, go into Settings - Hardware - Display Refresh Speed to Low. That solved it for me.
Publié : 10/05/2025 4:18 pm
1 personnes ont aimé
