					                		Layer offset problems - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-assembly-and-first-prints-troubleshooting/layer-offset-problems/</link>
                <lastBuildDate>Wed, 11 Mar 2026 19:38:21 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-assembly-and-first-prints-troubleshooting/layer-offset-problems/#post-726825</link>
                        <pubDate>Mon, 11 Nov 2024 23:14:22 +0000</pubDate>
                        <description><![CDATA[By the look of your alpaka your belts could still use some attention.It&#039;s time to start designing your own; begin small and simple so the early mistakes are also small and simple and build u...]]></description>
                        <content:encoded><![CDATA[<p>By the look of your alpaka your belts could still use some attention.</p><p>It's time to start designing your own; begin small and simple so the early mistakes are also small and simple and build up as you gain experience.</p><p>Cheerio,</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-assembly-and-first-prints-troubleshooting/layer-offset-problems/#post-726825</guid>
                        <title>RE: Layer offset problems</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-assembly-and-first-prints-troubleshooting/layer-offset-problems/#post-726819</link>
                        <pubDate>Mon, 11 Nov 2024 20:36:25 +0000</pubDate>
                        <description><![CDATA[Thank you Diem for this precise and very clear answer.I now understand why I got these results.I thought I understood from certain information on the web that this type of error came from to...]]></description>
                        <content:encoded><![CDATA[<p>Thank you Diem for this precise and very clear answer.</p><p>I now understand why I got these results.</p><p>I thought I understood from certain information on the web that this type of error came from too much demand on the machine, so I launched a new print with the Alpaka and it was quite a success.</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/11/ff8d9144-alpaka_1.jpg"><img class="alignnone size-medium wp-image-171675" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/11/ff8d9144-alpaka_1-600x500.jpg" alt="" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/11/121661ef-alpaka_2.jpg"><img class="alignnone size-medium wp-image-171674" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/11/121661ef-alpaka_2-600x500.jpg" alt="" width="600" height="500" /></a></p><p>Compared to step 26, I think I paid close attention to this step, but I will not hesitate to check again.</p><p>I also put my monthly equipment check on the calendar.</p><p>Thanks again for your feedback.</p><p>Beautiful day or evening.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Cevim srl</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-assembly-and-first-prints-troubleshooting/layer-offset-problems/#post-726819</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-assembly-and-first-prints-troubleshooting/layer-offset-problems/#post-726813</link>
                        <pubDate>Mon, 11 Nov 2024 19:51:47 +0000</pubDate>
                        <description><![CDATA[The Prusa plaque and to a lesser extent, the spatula, are designed to be easy to print and to succeed on most new builds as a confidence boost.The benchy is a torture test to be used to chec...]]></description>
                        <content:encoded><![CDATA[<p>The Prusa plaque and to a lesser extent, the spatula, are designed to be easy to print and to succeed on most new builds as a confidence boost.</p><p>The benchy is a torture test to be used to check most of the parameters affected by fine tuning, frankly, a perfect benchy, whilst good, is irrelevant on a newly built machine as most of the fine tuning will drift as the printer shakes down and runs-in.  All the initial setting up will have to be rechecked at your first monthly maintenance session after which there is a good chance the machine will remain stable indefinitely.</p><p>The Bonkers Benchy is just that, bonkers, it is a nod to a minority sport racing to produce a benchy in minimal time - in the process it loses most of the benchy's useful diagnostic properties and just produces a flimsy, useless, trinket.  That said, it is only printable on a perfectly calibrated machine but may well stress that machine so much that it needs attention before attempting a second one.</p><p>I am going to ignore your first Bonkers Benchy, it's quite good for a new build.  Your second and third Benchy's suggest the first shook loose a slight misbuild.</p><p>Check the tension in your belts.  If they have not come loose take a look at Step 26 of:  https://help.prusa3d.com/guide/3-x-axis-x-carriage-assembly_707749</p><p>(and the equivalent step for the Y motor) Did you make sure the grub screw faced the flat on the motor shaft?</p><p>Cheerio,</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-assembly-and-first-prints-troubleshooting/layer-offset-problems/#post-726813</guid>
                        <title>Layer offset problems</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-assembly-and-first-prints-troubleshooting/layer-offset-problems/#post-726771</link>
                        <pubDate>Mon, 11 Nov 2024 08:39:50 +0000</pubDate>
                        <description><![CDATA[Hello community,I became the owner of the Prusa MK4S. Very happy (and relieved) to have finished assembling the printer.I performed the self test and everything was ok. I updated the firmwar...]]></description>
                        <content:encoded><![CDATA[<p>Hello community,</p><p>I became the owner of the Prusa MK4S. Very happy (and relieved) to have finished assembling the printer.</p><p>I performed the self test and everything was ok. I updated the firmware, I am in 6.1.4+7908.</p><p>So I tested a few prints to get an idea of ​​the machine's performance. Unfortunately, everything did not go well.</p><p>Indeed my first impression was perfect in my eyes.</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/11/9310c03e-orig.jpg"><img class="alignnone size-medium wp-image-171650" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/11/9310c03e-orig-600x500.jpg" alt="" width="600" height="500" /></a></p><p>Then I tried the BonkersBenchy and there I had my first fault.</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/11/4065da8d-bch8_12.jpg"><img class="alignnone size-medium wp-image-171651" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/11/4065da8d-bch8_12-600x500.jpg" alt="" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/11/e863354d-bch8_11.jpg"><img class="alignnone size-medium wp-image-171652" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/11/e863354d-bch8_11-600x500.jpg" alt="" width="600" height="500" /></a></p><p>Then I tried spatula and again no problem. But immediately, I tried the BenchyRules and again the lag problem, but this time much more pronounced. Not having enough filament left, I gave up printing.</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/11/9f41b735-spat.jpg"><img class="alignnone size-medium wp-image-171653" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/11/9f41b735-spat-600x500.jpg" alt="" width="600" height="500" /></a></p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/11/95b36519-bch14.jpg"><img class="alignnone size-medium wp-image-171655" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/11/95b36519-bch14-600x500.jpg" alt="" width="600" height="500" /></a></p><p>This morning, new attempt on the BonkersBenchy and another big shift in layers but the printing ends.</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/11/22f137e7-bch8_2.jpg"><img class="alignnone size-medium wp-image-171654" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/11/22f137e7-bch8_2-600x500.jpg" alt="" width="600" height="500" /></a></p><p>I'm quite perplexed and lost. Do you have any ideas for me or even better a solution to the problem?</p><p>Thank you in advance for your time.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-assembly-and-first-prints-troubleshooting/layer-offset-problems/#post-726771</guid>
