Heatbed heater failing
Hussain
(@hussain-2)
So this issue has been going on since the start. This is self-assembly kit. Here are the attempts to fix:
1- Checked with multimeter all resistances and voltages
2- Tried with Satin sheet, PEI sheet, no sheet
3- Changed heatbed cables to xBuddy Box
4- Changed heatbed thermistor
5- Fully changed heatbed assembly
After changing the FULL heatbed aseembly, still no luck. Where can the issue be? It surely cannot be the heatbed. Temp reaches 68/110C during test only.
Can it be the xBuddy? what else can I try?
This topic was modified před 2 weeks by Hussain
Napsal : 23/04/2026 5:27 pm
For all problems with new builds and new machines the best resource is Prusa Support via chat.  You will need your serial number.
Napsal : 24/04/2026 4:19 am
