First Print Problems
John
 John
(@john)
Not sure if anyone else has come accross this problem but I'll share my experience anyway.
My first prints were a total failure, not getting beyond the second layer with a birds nest of filament engulfing the nozzle. I also noticed that there was a lot of noise while the printing was in progress and realised that the fan shroud was scraping across the print. The solution was to release the nozzle assembly and drop enough to be lower that the shroud. Both shroud and nozzle were installed as per the instrutions so no idea why the shroud ended up being lower than the nozzle.
Anyway, all is good now and my first two test prints, keychain and benchy, were very good.
Posted : 30/10/2024 10:01 am
vhubbard
(@vhubbard)
RE: First Print Problems
Picutres help for others to see the problem.
Pushing the nozzle up too far is very hard to do.  It touches the mainplate in the nextruder.   If the nozzle is pulled down, it may be too far from the gears or filament end in the nextruder.   This could cause problems with filament changes.
 There are two notches on the nozzle that align with the screws.  If the screws are in the notches and the fan is scraping, something is wrong with the fan assembly.
Posted : 01/11/2024 2:57 pm
