First layer not filling perfectly
Didn't have this issue before my MK4S upgrade, but my first layers on some parts have been haven't been filling properly. I will be tinkering with temps/speeds on first layer to fix this since I assume it's a HF nozzle issue(tempted to just go back to regular nozzles as this thing has only caused issues), but wanted to post here for any other insight or if someone else has come across this.
RE: First layer not filling perfectly
See https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4254 Hopefully adjusting live Z will fix it for you, it does for me, until Prusa finally provides a firmware fix.
I set z-offset to 0.04 on almost everything I slice for the MK4S for this very reason.
MK4S/MMU3
Wow.. so weird that a firmware mistake can cause this when it was fine before. Nuts that this isnt hotfixed by now. Thanks!
