GPIO - Panasonic LUMIX G95D's Focus and Shutter Not Triggering
Alias
(@alias)
Printer: Original Pusa MK4S MMU3
  • Bootloader: 2.3.5
  • Additions: GPIO Hackerboard and Panasonic LUMIX G95D
Prusa Slicer: 2.9.0
I'm currently trying to connect my Panasonic LUMIX G95D to the GPIO board, so I can make timelapses of my printers.
However, I was having a difficult time in triggering the focus and shutter. Thankfully, I found a video by Zemistr 3D titled "Time-lapse videos with Prusa GPIO Hacker board and camera using cable shutter trigger".
So, I decided to conduct the following tests:
  1. Used tweezers to probe Pin 0 and Pin 1 along with Pin 0 and Pin 2 on the GPIO board to ensure all my connections were solid (i.e., verifying it can trigger my camera's focus and shutter)
  2. Used tweezers on the 2.5mm adapter to ensure it can trigger the camera's focus and shutter
Then I went on and created a Template Custom G-Code in PrusaSlicer in Printers > Custom G-Code and called {template_custom_gcode} at the end of Before layer change G-code and at the top of End G-Code.
I noticed the nozzle does move to the right parking position, however, the camera isn't triggered? I looked in the .gcode and the template G-Code is present there.
I did notice on GPIO Module | Prusa Knowledge Base it said: "To utilize the full potential of the GPIO board you need firmware 6.2.0-alpha1 or newer."
Evidently, my Prusa's bootloader is a few versions behind. However, I wanted to ask if there's any missteps/further guidance/troubleshooting techniques on this topic?
Template Custom G-Code by Zemistr 3D
;Time-lapse - startM262 P0 B0 ;Pin 0 as output
M262 P1 B0 ;Pin 1 as output
G1 X241 Y170 F10000 ;Park on position
G4 P500 ;Wait 500ms
M264 P1 B1 ;Trigger focus
M264 P0 B1 ;Trigger shutter
G4 P300 ;Wait 300ms
M264 P0 B0 ;Release shutter
M264 P1 B0 ;Release focus
G4 P500 ;Wait 500ms;
Time-lapse - end
Postato : 24/05/2025 7:34 pm
LarGriff
(@largriff)
RE: GPIO - Panasonic LUMIX G95D's Focus and Shutter Not Triggering
I think you’re on the right track with updating the printer firmware.  I believe 6.2.4 is current and it works with my GPIO.  The rest of your script looks okay.
MK4S/MMU3
Postato : 25/05/2025 2:50 am
Alias
(@alias)
@LarGriff
Thank you for confirming the script!
Apologies, I'm on 6.1.4+7908.
When I attempt to update my printer's firmware using the guide below with all the options (i.e., flash drive, over the air, etc.). My printer just restarts, but doesn't flash the new firmware.
https://help.prusa3d.com/article/how-to-update-firmware-core-one-mk4-s-mk3-9-s-mk3-5-s-xl_453086
Perhaps, it could be camera setting but that seems debunked with being able to trigger it using tweezers and this button:
Kiwifotos DMW-RSL1 Remote Control Shutter Release Cord for Panasonic G9
Postato : 25/05/2025 3:59 am
_KaszpiR_
(@_kaszpir_)
You need to flash firmware to 6.2.x or newer, bootloader is another story.
AFAIR you can reboot the printer and double click the spin wheel when its booting to force searching for a firmware update files on the pendrive ( similar to firmware downgrade). Just make sure to place single update firmware on the pendrive ( remove old updates).
Or do a factory reset which also loads firmware file from the pendrive.
Postato : 25/05/2025 8:55 am
Alias
(@alias)
@_kazpir_
Nice, thank you for confirming. I've just flashed printer's firmware to 6.2.4, however, the issue still persists.
This leads me to believe it's either of the following:
I've rechecked my .gcode and the G-Code template in my original posts are present.
Postato : 25/05/2025 7:49 pm
LarGriff
(@largriff)
On second glance, look at your code again.  Maybe the first two lines are run together?
Posted by: @alias
  • Bootloader: 2.3.5
Prusa Slicer: 2.9.0
;Time-lapse - startM262 P0 B0 ;Pin 0 as output     <<< This line needs to be split
G4 P500 ;Wait 500ms
G4 P300 ;Wait 300ms
Time-lapse - end
MK4S/MMU3
Postato : 26/05/2025 12:36 pm
1 persone hanno apprezzato
Alias
(@alias)
My apologies about that, I should have provided the screenshots as well.
All the lines run with no error, I noticed the printer moves the nozzle to the correct park location.
However, when it runs lines related to M262 or M264. I don't notice anything occurring on my camera.
Postato : 26/05/2025 12:57 pm
LarGriff
(@largriff)
You likely have already seen this, but the following thread has a little more info on the topic.
https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-add-ons/gipo-canon-eos-r8-2-5mm/
Cheers!
MK4S/MMU3
Postato : 26/05/2025 11:35 pm
Zemistr
(@zemistr)
First I'd like to thank you for watching my video. 😊
Second, I read what you wrote here and I would like to verify a few things.
You wrote that you used metal tweezers to verify that the camera would focus and that the camera would take a picture. Can you please confirm this and possibly attach photos of how you positioned the tweezers for focusing and how to take the photo?
If I understand correctly, you have already updated the firmware to the latest version, right?
I can see in the screenshots that you changed the G4 P300 command to G4 P30 only. It may not seem like it, but the camera takes a while to register queries, so I recommend not shortening this delay too much.
Also, the Prusa GPIO Hackerboard needs to be connected when the printer is started. When the printer starts, the last pin configuration is sent to the board and the board then works as it should.
And maybe one more little thing.That parking and taking pictures doesn't work well when using MMU, because MMU changes the order of G-Code commands and so parking and trying to take pictures happen in a strange order. 🙁
Postato : 27/05/2025 11:36 pm
Alias
(@alias)
Good evening everyone,
Firstly, I would like to thank you all for your incredible support and more than generous assistance on this post! Such an awesome community!
I've taken both @largriff and @zemistr incredible advice on relooking at the other forum post, increasing the wait times (i.e., I increased them all to 500ms), and making sure the board is plugged in before turning on the printer. It now works flawlessly; the solution was the combination of increasing the wait times and plugging the board in before turning on the printer along with thoroughly looking through the other forum posts for any other mistakes.
@zemistr, thank you tremendously for putting together an excellent set of videos on this topic! It made it so much more approachable and understandable!
I've attached the timelapse below!
Postato : 30/05/2025 2:30 am
2 persone hanno apprezzato
Zemistr
(@zemistr)
I don't see any video but I'm happy that it works now for you. ☺️
Postato : 30/05/2025 7:22 pm
