Advanced filtration system HEPA filter fan not turning. POWER light not on
Hello! I just installed the HEPA filter but the fan is not turning. Seems like the basic board doesn't work since the POWER light is not on. See the picture. I am using the External PSU Delta model MEA-065A24C.
Any suggestions to make this work?
Opublikowany : 31/12/2024 8:55 am
RE: Advanced filtration system HEPA filter fan not turning. POWER light not on
Did you figure out something here to make it work? Same issue here, curious if it's a faulty board.
Opublikowany : 25/08/2025 10:25 am
