Single extruder - Multi Color-print fails due clogged filament in nextruder
I tried to print multicolor with one extruder but sadly, when I should change the filament, the filament gets stuck in the nextruder whenever it retracts it to change. When I remove the clogged filament and put in the second color, it purges on the tower that the nozzle touches the newly printed filament.
It seems like it retracts a "drop" filament so far, it gets stuck in the gearbox itself.
It is everytime a pain to loosen the clogged filament and get it back to work.Why is it doing this?
My settings I changed:
- 2 Extruders
- Single Extruder
- M600 in the filament change code
Posted : 20/01/2025 6:54 pm
