Protrusion on circular objects
The printing of circular objects creates a slight protrusion for me, which is then noticeable over the entire height of the object (see the photo where there is the A of PIA). The grey object is printed with an MK3S+, the blue one with an MK4, but the defect is similar. Can anyone tell me if it is possible to eliminate this defect?
Thank you
Opublikowany : 27/01/2024 8:53 pm
This really ought to be a sticky topic.
You need to be in advanced mode to do this:
Go to: Print Settings > Layer and perimeters > Advanced > Seam position and try different settings.
Opublikowany : 28/01/2024 12:30 am
