No bed leveling done before print
Hello,
Usually when I print something from printables, there is always a bed leveling session done by the MK4 before printing.
However, now that I am trying to print 3mf files from 3dLabPrint (plane parts), there is no leveling anymore, which doesn't help for first layer adhesion.
How do I trigger this automatically on every print ? I can't find anything in PrusaSlicer to do it.
Thanks for your help.
RE: No bed leveling done before print
in expert mode, have a look in Printer settings>custom Gcode> Start Gcode
I assume these 3mf files replaced your printer profile with something else that doesn't include bed leveling in the startup gcode. If you know what you're doing you can insert the respective code. Or try simply switching to a standard Mk4 printer profile
Precisely, 3mf load settings for the printer and filament that change everything.
I hoped that I could trigger from Prusa Slicer an option with a checkbox or something, or directly from the printer via menus.
Is there anything like this ?
