How to print with 3D LabPrint PolyLight 1.0 LW-PLA
Fred
 Fred
(@fred)
I have had great success using their slicer settings for the MK3. I then followed their instructions for manually adjusting the print settings for use on MK4.
After slicing, the expected print time for a part was over twice the time and half again the amount of filament for the MK4. I did not try to print the part.
Anyone have experience with this LW-PLA on an MK4?
3D LabPrint has been no help. They apparently think slicing for MK4 is the same as MK3.
Posted : 24/12/2023 11:44 pm
Thomas Cowieson
(@thomas-cowieson)
RE: How to print with 3D LabPrint PolyLight 1.0 LW-PLA
I am having the same problem.  I sliced using Prusa slicer but it doesn't have the original fill expected it is very Heavy. I did 12 hours worth of printing before I noticed.
I was going to try printing with Standard PLA
3d Print lab has not responded to me either.  Maybe PRUSA can help us with this.  As the prusa website is how i found out about the planes
Posted : 25/12/2023 5:30 pm
Renze
(@renze)
I also sent their support an email on October 13th and never got a response...
Is it posible to just use the mk3 gcodes on the MK4? The biggest thing to take under consideration is the bed leveling I guess. Is that process incorporated in the gcode?
Posted : 27/12/2023 9:42 am
Greg
 Greg
(@greg-13)
Has anyone found a source for help on this yet? It seems like everything I find is intended for the MK3S and I'm finding nothing on the MK4 (or MK3.5 which is what I have)
Posted : 12/04/2024 10:04 pm
Warthog Woodworking
(@warthog-woodworking)
I just printed the Center Wing Section of the 3d Print Labs Cub on a MK4 using the 3d Print Labs GCode.
Caution:  Because the GCode was not generated for the MK4, it didn't perform a bed leveling check and went straight to printing.  Using the 3d Print Labs GCode could risk a bad crash into the printing plate.  Use this GCode at your own risk.
The print worked well.  Much better than I was getting on the MK3.  Zero stringing.
Posted : 09/05/2024 9:43 pm
