How to ensure same infill for all instances regardless of angle orientation
Alexander Hyperbeam
(@alexander-hyperbeam)
I'm printing a batch of a part and I want every object to have identical infill structures but I can only seem to do that when on the plate I'm orienting all of the objects in the same direction. I'm able to fit more of the part onto the bed when I rotate the objects are various angles but the infill direction is now different for each part.
How do I get each object to have the exact same structure without sacrificing bed space?
Postato : 21/03/2025 6:13 pm
RE: How to ensure same infill for all instances regardless of angle orientation
Right-click>Add settings>Infill>Fill angle
Postato : 22/03/2025 10:50 pm
As Foxrun says you will have to use modifiers and some math.  Infill angle is not tied to the part but to the bed.  So you rotate the part but the infill is generated relative to the bed.  If you rotate 1 part 15 degrees then you will have to use a modifier to offset the angle by the same amount.  Its probably better/easier to add the modifier to your original part and explicitly set the angle you want and then duplicate and manually rotate the others and note the angle you rotated by and then adjust the modifier.
Postato : 22/03/2025 11:27 pm
Alexander Hyperbeam
Ah ok thanks. That's more tedious than I imagined. I would have imagined Prusaslicer had some sort of "identical instance structure" setting
Postato : 23/03/2025 3:37 pm
