					                		Why no image of what is printed? - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/why-no-image-of-what-is-printed/</link>
                <lastBuildDate>Thu, 11 Jun 2026 20:01:23 +0000</lastBuildDate>
                        <title>RE: Why no image of what is printed?</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/why-no-image-of-what-is-printed/#post-714667</link>
                        <pubDate>Tue, 25 Jun 2024 15:51:15 +0000</pubDate>
                        <description><![CDATA[Thanks, I will give it a try. That option is under Configuration/Preferences/Other.]]></description>
                        <content:encoded><![CDATA[<p>Thanks, I will give it a try. That option is under Configuration/Preferences/Other.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Kevin</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/why-no-image-of-what-is-printed/#post-714667</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/why-no-image-of-what-is-printed/#post-714663</link>
                        <pubDate>Tue, 25 Jun 2024 15:20:32 +0000</pubDate>
                        <description><![CDATA[Not 100% sure but you do have binary gcode enabled, right? It should be a few lines down below the thumbnail options. Beyond that maybe check if there are any configuration updates or I gues...]]></description>
                        <content:encoded><![CDATA[<p>Not 100% sure but you do have binary gcode enabled, right? It should be a few lines down below the thumbnail options. </p><p>Beyond that maybe check if there are any configuration updates or I guess you could try entering,</p><p>16x16/QOI, 313x173/QOI, 440x240/QOI, 480x240/QOI, 640x480/PNG</p><p>in the box and saving it as a new printer configuration.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>ironfan72</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/why-no-image-of-what-is-printed/#post-714663</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/why-no-image-of-what-is-printed/#post-714597</link>
                        <pubDate>Mon, 24 Jun 2024 23:59:32 +0000</pubDate>
                        <description><![CDATA[So how do I change it? PrusaSlicer 2.7.4  This is what is set for the G Code Thumbnail and it is locked: 16x16/PNG, 313x173/PNG, 440x240/PNG.]]></description>
                        <content:encoded><![CDATA[<p>So how do I change it? PrusaSlicer 2.7.4  This is what is set for the G Code Thumbnail and it is locked: 16x16/PNG, 313x173/PNG, 440x240/PNG.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/why-no-image-of-what-is-printed/#post-714597</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/why-no-image-of-what-is-printed/#post-714584</link>
                        <pubDate>Mon, 24 Jun 2024 21:57:08 +0000</pubDate>
                        <description><![CDATA[Initially it sounds like a QOI vs PNG issue. Here&#039;s the section from the firmware release notes that introduced QOI. QOI instead of PNG (XL, MK4, MINI)Until this release, the thumbnails for ...]]></description>
                        <content:encoded><![CDATA[<p>Initially it sounds like a QOI vs PNG issue. Here's the section from the firmware release notes that introduced QOI.</p><p> </p><p>QOI instead of PNG (XL, MK4, MINI)</p><p>Until this release, the thumbnails for G-code were in PNG format, which was rather resource-heavy. We have decided to switch to another format called QOI, which is way less demanding, and we can utilize the freed-up resources to bring more features in future releases.</p><p>The only downside of removing the support for PNG is that all the G-codes sliced until now, won't have a visible thumbnail on firmware 5.1.0 or newer. For now, the only solution is to reslice the G-code in PrusaSlicer 2.7.0 or newer.</p><p> </p><p>In expert mode you can look under the printer settings and see what file formats are listed for G-code thumbnails.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/why-no-image-of-what-is-printed/#post-714584</guid>
                        <title>Why no image of what is printed?</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/why-no-image-of-what-is-printed/#post-714565</link>
                        <pubDate>Mon, 24 Jun 2024 18:18:08 +0000</pubDate>
                        <description><![CDATA[Prusa Mk4 with latest firmware. Prusa Slicer 2.7.4.  I slice something but when I go to print it from the Mk4, no image appears on the screen of the Mk4 of what is going to print. What am I ...]]></description>
                        <content:encoded><![CDATA[<p>Prusa Mk4 with latest firmware. Prusa Slicer 2.7.4.  I slice something but when I go to print it from the Mk4, no image appears on the screen of the Mk4 of what is going to print. What am I doing wrong?</p><p>Thanks</p><p>Kevin</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/why-no-image-of-what-is-printed/#post-714565</guid>
