Printer not cooling down after print
I’m on my 3rd Prusa printer. Using an MK4 with MMU. The printer used to always cool down right after a print. With newest slicer version it waits 30 minutes before cooling down. So I just do cool down in the filament area.
Is there a setting to change to cool down immediately after print. Or a G code change I could make?
thanks, Jon
RE: Printer not cooling down after print
Under the settings for your selected printer in PrusaSlicer, what do the custom g-codes look like? Specifically the end g-code section?
{if layer_z < max_print_height}G1 Z{z_offset+min(layer_z+1, max_print_height)} F720 ; Move print head up{endif}M104 S0 ; turn off temperatureM140 S0 ; turn off heatbedM107 ; turn off fanG1 X241 Y170 F3600 ; park{if layer_z < max_print_height}G1 Z{z_offset+min(layer_z+23, max_print_height)} F300 ; Move print head up{endif}G4 ; waitM900 K0 ; reset LAM142 S36 ; reset heatbreak target tempM84 X Y E ; disable motors; max_layer_z = [max_layer_z]
