[Solved] Power Disconnect plug
l3art
(@l3art)
Hello, I saw that for the MK3S there is a way foreseen to have a plug system to disconnect the power when using the Prusa enclosure. This is not the case for a MK4. Is there a way to do this. BTW, I don't use the Prusa Enclosure, but a Lack enclosure, but the system should be similar, I guess...
Best Answer by ScottW:
The "PSU Cable Quick-release" accessory is not currently compatible with the MK4, because the wiring for the power-panic feature is different.  Multiple MK4 owners have reported being told by Prusa Support that a version compatible with the MK4 will be available by "late summer".  No specific date has been given as far as I know.
There was another thread were at least one MK4 user was able to adapt the existing MK3 version by adding a different cable for the power-panic.  Specifically, take a look at the second paragraph of this post:
https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/mk4-display-cable-to-short-for-the-prusa-original-enclosure/#post-657125
Posted : 04/09/2023 9:21 am
ScottW
(@scottw)
RE: Power Disconnect plug
Posted : 04/09/2023 10:57 pm
l3art
(@l3art)
Thanks for pointing me in that direction. I certainly will have a look at it!
Posted : 05/09/2023 6:38 am
