Nextruder print fan doesn't fully close
Steve
(@steve-4)
Unless you run the hotend wires (the heater and thermistor wires) perfectly, the Nextruder fan doesn't fully close.
Has anyone solved this problem?  Sounds like the fan mount should have a  bit more space than it currently has so it can close properly even if the wires aren't perfectly in. Looks like a Prusa engineering flaw.
Senior Life member of IEEE.
Posted : 09/11/2023 3:10 pm
VOJTAšák
(@vojtasak)
It happened to me too and I had wires between the nozzle holding gears and the heatsink
Posted : 18/11/2023 7:04 am
kengineer
(@kengineer)
RE: Nextruder print fan doesn't fully close
For me it was also the wires not tucked into the too small channel they were designed to be in.
Posted : 21/11/2023 7:56 pm
Steve
(@steve-4)
This is a really bad design by Prusa.  I am trying to get the original 3D model files from Prusa for the fan door and fan shroud so I can modify them.  I tried to convert their stl files into files my CAD system (Alibre Designs) can use, and the converted file was full of holes.
If I ever get the model files, I'll print the fan door in PC and the shroud in PEEK.
Posted : 21/11/2023 8:13 pm
