MK4 randomly unloading filament during prints?
JAnger
(@janger)
Hi
My MK4 has started randomly unloading the filament during a print. It then sits there waiting till I notice - click that the filament was successfully unloaded and then tell it to load the filament. The print job then resumes until it randomly ejects the filament again. This could happen a few times during a 4 hour print.
I've turned the filament sensor off and the behaviour is the same. I've updated to 4.6.2. firmware and it is the same. Same behaviour on different prints and with different filaments.
Anyone else? I guess I'll email support.
Postato : 05/05/2023 9:30 pm
JAnger
(@janger)
RE: MK4 randomly unloading filament during prints?
I discovered the power cord was loose - but also support recommended I stop using the alpha slicer release and use 2.5.2 or the latest stable release. Trying it again here.
Postato : 05/05/2023 10:29 pm
JAnger
(@janger)
My MK3S+ also ejected filament during a print - again using the Alpha 6 slicer for 2.6v. I went back to slicer 2.5.2. Seems to have solved this weird problem so far. It's strange though I've printed many prints with the alpha slicer with no issues. Why now suddenly?
Postato : 07/05/2023 2:54 am
BrutusBoots
(@brutusboots)
This may seem silly but are you accidentally inserting pauses into your prints in PrusaSlicer and not realizing it?
Postato : 11/05/2023 6:21 pm
Peki
 Peki
(@peki)
I have the same problem. looks like problem with filament sensor. but I don ‘t found filament sensor yet,  as well no manual showing it. looks you have fixed it. going to print another part, as well to slice and print, change slicer,  to test if it is hardware or software problem.
Questo post è stato modificato 2 years fa 2 tempo da Peki
Postato : 16/05/2023 6:42 am
iftibashir
(@iftibashir)
A pause shouldn't automatically unload the filament.....
Posted by: @brutusboots
Postato : 19/05/2023 8:23 am
Marcel V
(@marcel-v)
Utenti
At first I though I had some colour changes in the gcode by accident bu that wasn't the case. In my case this only happens with a light gold/yellow coloured filament of a certain brand. I am going to check if the filament sensor can be disabled for the MK4.
Postato : 09/06/2023 4:29 pm
Ben David
(@ben-david)
Utenti
Since new - I have had issues with the filament sensor on the MK4 - false reporting "no filament" - I contacted support - recommendation was to open the filament door and blow out the drive gear area - no change.  Found that as I rotated the filament - ie, from 270 deg to 180 deg, or from left to facing forward - the sensor would indicate "no filament" - in desperation - I removed the 3 screws that hold the planetary gears in place on the front of the extruder - removed the planetary gear set - reinstalled the drive gear/planetary gear set - that must have dislodged material I couldn't see - because the filament sensor is now working correctly - ie, the filament can be inserted and rotated 360 deg - remains detected!  As an FYI - this is a factory assembled printer - and I am not recommending anyone disassemble their printer - but this worked for me....your mileage may vary....
Postato : 11/06/2023 6:18 pm
steve457
(@steve457)
I just completed assembling my MK4 this past weekend, and ran into this same issue with my first print using PLA. The print was about 20 minutes in total, but the filament auto ejected about halfway through the print. Interestingly enough the filament color was light gold/beige in color, similar to what Marcel V reported having issues with. I've since printed over 15 hours using black PETG and have not run into the problem again, so it definitely appears that the light gold color filament causes problems.
I'm curious though why the filament would auto eject? Shouldn't the printer pause and ask you to press the button before ejecting filament (similar to what the MK3 does)?
Postato : 13/11/2023 5:26 pm
Pepsimax
(@pepsimax)
Utenti
I have the same problem. Printing yellow petg om MK4
Slicer 2.7.1 and firmware 5.1.0
Questo post è stato modificato 2 years fa da Pepsimax
Postato : 19/12/2023 12:57 pm
rikifriki
(@rikifriki)
Utenti
same issue here mk4 with Slicer 2.7.1 and firmware 5.1.0
Postato : 22/01/2024 12:32 pm
Austere Research
(@austere-research)
Utenti
Same issue. Trying again with filament sensor disabled.
Postato : 04/04/2024 12:05 am
Pcbh
 Pcbh
(@pcbh)
Utenti
Same on my MK3S.
Postato : 17/07/2024 12:34 pm
UnionJak68
(@unionjak68)
Utenti
This may not be relevant to you guys now... Sorry!
I have a MK3.9, which I recently upgraded to a MK3.9S. I have experienced the filament reload/jam stuff also.
I remember having this when I first upgraded to MK3.9. I had to disable jam monitoring. So I have disabled "Stuck Filament Detection" with the S! Now no problems! Sure this is the same for the MK4S.
Shame as this would be a good thing to have if it was reliable?
Postato : 08/02/2025 7:00 am
evilphoton
(@evilphoton)
my problem was different so I don't know if there's anything to learn. after heating up and wiping the nozzle on the front of the plate, the head would go off to the right and park and ask for a filament change. not during a printing job though, only before and it did go away by turning off the filament sensor through the interface [mk4].
I took it apart anyway to see if anything didn't look right. the screw that holds the filament sensor in place was loose enough to wiggle in the threads. I put a dab of loctite on the screw and put it back in tightening snugly. I don't know if the sensor was able to move around or what, but it isn't asking for a filament change anymore. maybe it was vibrating enough to trigger the sensor somehow? also the threaded pin that the filament tension arm hinges on was loose too.
Postato : 10/02/2025 11:40 pm
1 persone hanno apprezzato
