					                		MK4 Power Panic Issue - Can&#039;t boot - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/</link>
                <lastBuildDate>Mon, 08 Jun 2026 14:52:30 +0000</lastBuildDate>
                        <title>RE: MK4 Power Panic Issue - Can&#039;t boot</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-705099</link>
                        <pubDate>Sat, 23 Mar 2024 07:49:17 +0000</pubDate>
                        <description><![CDATA[I tried this on my new just built XL to try an fix the power panic error an it did not work so its something else even flashing back an forward dont fix it alwasy red screen of death cant ge...]]></description>
                        <content:encoded><![CDATA[<p>I tried this on my new just built XL to try an fix the power panic error an it did not work so its something else even flashing back an forward dont fix it alwasy red screen of death cant get past that do to this cable error I so believed in them an its dying now due too this! I got ripped on crap machine long ago once was even way less too but at least I got to print things for a bit with that machine this one will not let me even start it out to calibrate it.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>EliwazMoonitz</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-705099</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676396</link>
                        <pubDate>Thu, 28 Sep 2023 01:45:05 +0000</pubDate>
                        <description><![CDATA[It&#039;s an xbuddy board. I see that on yours now. You are missing the white connector. However, you can see where it should have been. And while the white wire pin is ripped off your PCB, you c...]]></description>
                        <content:encoded><![CDATA[<p>It's an xbuddy board. I see that on yours now. You are missing the white connector. However, you can see where it should have been. And while the white wire pin is ripped off your PCB, you can still solder a jumper wire to the resistor or cap I pointed out.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>IBNobody</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676396</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676395</link>
                        <pubDate>Thu, 28 Sep 2023 01:40:26 +0000</pubDate>
                        <content:encoded><![CDATA[<p><img src="https://i.imgur.com/qsPrg1R.jpg" /></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676395</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676394</link>
                        <pubDate>Thu, 28 Sep 2023 01:35:25 +0000</pubDate>
                        <description><![CDATA[Posted by: @ibnobody Wow! I&#039;ve never seen that board. Are you sure it&#039;s an xbuddy for a MK4? Can you take larger pictures of the rest of the board? There should be a version number on it as ...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="283225" data-postid="676393" data-mention="ibnobody"><div class="wpforo-post-quote-author"><strong> Posted by: @ibnobody </strong></div><p>Wow! I've never seen that board. Are you sure it's an xbuddy for a MK4? Can you take larger pictures of the rest of the board? There should be a version number on it as well.</p></blockquote><p>Could you take a large one of yours please I see power panic written on jmshirly one but there is no port near by so I'm wondering if it's a faulty board </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Hello</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676394</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676393</link>
                        <pubDate>Thu, 28 Sep 2023 01:01:57 +0000</pubDate>
                        <description><![CDATA[Wow! I&#039;ve never seen that board. Are you sure it&#039;s an xbuddy for a MK4? Can you take larger pictures of the rest of the board? There should be a version number on it as well.]]></description>
                        <content:encoded><![CDATA[<p>Wow! I've never seen that board. Are you sure it's an xbuddy for a MK4? Can you take larger pictures of the rest of the board? There should be a version number on it as well.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676393</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676383</link>
                        <pubDate>Wed, 27 Sep 2023 23:09:23 +0000</pubDate>
                        <description><![CDATA[This is what I&#039;m seeing on my board. Sorry, it&#039;s not a great picture. But I feel like it&#039;s not even the same one.]]></description>
                        <content:encoded><![CDATA[<ol>
<li><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/09/0606b5c8-20230927_171110-scaled.jpg"><img class="alignnone size-medium wp-image-157601" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/09/0606b5c8-20230927_171110-600x500.jpg" alt="" width="600" height="500" /></a>This is what I'm seeing on my board. Sorry, it's not a great picture. But I feel like it's not even the same one.  <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/09/01e5c59a-20230927_170557-scaled.jpg"><img class="alignnone size-medium wp-image-157600" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/09/01e5c59a-20230927_170557-600x500.jpg" alt="" width="600" height="500" /></a></li>
</ol>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>jmshirley</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676383</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676343</link>
                        <pubDate>Wed, 27 Sep 2023 18:36:39 +0000</pubDate>
                        <description><![CDATA[If you absolutely need to, these are some of the pins you can short to GND to trick the power panic into thinking it is ok.]]></description>
                        <content:encoded><![CDATA[<p><img src="https://i.imgur.com/8QgAEJO.jpg" alt="" /></p><p>If you absolutely need to, these are some of the pins you can short to GND to trick the power panic into thinking it is ok.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676343</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676323</link>
                        <pubDate>Wed, 27 Sep 2023 15:22:07 +0000</pubDate>
                        <description><![CDATA[The problem I&#039;m having is that both the little pins on the board broke off and it was literally just a small box that slides onto the pins. A friend has been trying to solder directly onto t...]]></description>
                        <content:encoded><![CDATA[<p>The problem I'm having is that both the little pins on the board broke off and it was literally just a small box that slides onto the pins. A friend has been trying to solder directly onto the contact points with zero success as he can't get the solder to hold. Looking at the pictures in that github link makes me wonder if something pulled off the board that wasn't supposed to because I never had a small white box on the board when I opened mine up for the first time and found it disconnected. If that's the case then I'm about to try the solution mentioned by getting some new wire and trying to solder in a single line in the configuration mentioned. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676323</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676270</link>
                        <pubDate>Wed, 27 Sep 2023 07:50:58 +0000</pubDate>
                        <description><![CDATA[Posted by: @ibnobody Everyone! Other users found a solution to this and posted it in my Github issue.Conclusion: Disconnect the black wire from the power panic, while leaving the white wire ...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="283225" data-postid="676179" data-mention="ibnobody"><div class="wpforo-post-quote-author"><strong> Posted by: @ibnobody </strong></div><p>Everyone! Other users found a solution to this and posted it in my Github issue.</p><blockquote><p><strong>Conclusion: Disconnect the black wire from the power panic, while leaving the white wire connected to "V-" (or any other point tied to PSU negative) will disable power panic AND disable the cable check portion of the power panic.</strong></p></blockquote></blockquote><p>Thank you very much. I can confirm: works fine with my Meanwell PSU :-)</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>tfhh</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676270</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676179</link>
                        <pubDate>Tue, 26 Sep 2023 19:42:30 +0000</pubDate>
                        <description><![CDATA[Everyone! Other users found a solution to this and posted it in my Github issue.Conclusion: Disconnect the black wire from the power panic, while leaving the white wire connected to &quot;V-&quot; (or...]]></description>
                        <content:encoded><![CDATA[<p>Everyone! Other users found a solution to this and posted it in my Github issue.</p><blockquote><p><strong>Conclusion: Disconnect the black wire from the power panic, while leaving the white wire connected to "V-" (or any other point tied to PSU negative) will disable power panic AND disable the cable check portion of the power panic.</strong></p></blockquote>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-power-panic-issue-cant-boot/#post-676179</guid>
