					                		MK4 PCB Connector type - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-pcb-connector-type/</link>
                <lastBuildDate>Sat, 18 Apr 2026 16:30:57 +0000</lastBuildDate>
                        <title>RE: MK4 PCB Connector type</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-pcb-connector-type/#post-733665</link>
                        <pubDate>Thu, 23 Jan 2025 11:16:33 +0000</pubDate>
                        <description><![CDATA[Hi my ZR connector fell off while the pins are still In the board, I can’t seem to find the exact part anyone know the part number?]]></description>
                        <content:encoded><![CDATA[<p>Hi my ZR connector fell off while the pins are still In the board, I can’t seem to find the exact part anyone know the part number?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Yaka</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-pcb-connector-type/#post-733665</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-pcb-connector-type/#post-711296</link>
                        <pubDate>Sat, 18 May 2024 08:43:35 +0000</pubDate>
                        <description><![CDATA[hi I saw that you both @mykal451 and @mekcreate a time ago had worked into pcb plug types on xbuddy. Might it be possible that you would be able to help me out by defining the plug types as ...]]></description>
                        <content:encoded><![CDATA[<p>hi </p><p>I saw that you both @mykal451 and @mekcreate a time ago had worked into pcb plug types on xbuddy. Might it be possible that you would be able to help me out by defining the plug types as descriped in my recent post : <a title="connector types" href="https://forum.prusa3d.com/forum/postid/710650/" target="_blank" rel="noopener">https://forum.prusa3d.com/forum/postid/710650/</a> </p><blockquote data-userid="0" data-postid="669089" data-mention=""><p>Example: pre-wired 8 conductor connector - series 015135 . . . full part number for 8 conductor - 0151350806</p><p>Example: pre-terminated red wire 450mm long (both ends have pin pre-installed) - series 215710 . . .  450mm length red wire - 2157102125</p></blockquote><p> </p><p>I would like to Order male - Female connector for each type to be able to make extension cable for xbuddy board. </p><p>thanks a lot</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>fhartmann</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-pcb-connector-type/#post-711296</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-pcb-connector-type/#post-669089</link>
                        <pubDate>Tue, 15 Aug 2023 03:15:32 +0000</pubDate>
                        <description><![CDATA[Was surprised to find that DigiKey sells fully pre-wired clik-mate connectors and also pre-terminated wires of different lengths / colors.Example: pre-wired 8 conductor connector - series 01...]]></description>
                        <content:encoded><![CDATA[<p>Was surprised to find that DigiKey sells fully pre-wired clik-mate connectors and also pre-terminated wires of different lengths / colors.</p><p>Example: pre-wired 8 conductor connector - series 015135 . . . full part number for 8 conductor - 0151350806</p><p>Example: pre-terminated red wire 450mm long (both ends have pin pre-installed) - series 215710 . . .  450mm length red wire - 2157102125</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Mykal451</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-pcb-connector-type/#post-669089</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-pcb-connector-type/#post-667261</link>
                        <pubDate>Thu, 03 Aug 2023 18:16:14 +0000</pubDate>
                        <description><![CDATA[HeyYes you are right. I also found out it was those and order some, and wonted to be sure it was those before posting.And yes it is, Molex CLIK-Mate 1.5mm pitch :) Posted by: @mykal451 Prett...]]></description>
                        <content:encoded><![CDATA[<p>Hey<br /><br />Yes you are right. I also found out it was those and order some, and wonted to be sure it was those before posting.<br />And yes it is, Molex CLIK-Mate 1.5mm pitch :)<br /><a href="https://forum.prusa3d.com/wp-content/uploads/2023/08/IMG_20230803_200925-scaled.jpg"><img class="alignnone size-medium wp-image-155507" src="https://forum.prusa3d.com/wp-content/uploads/2023/08/IMG_20230803_200925-600x500.jpg" alt="" width="600" height="500" /></a></p><blockquote data-userid="60405" data-postid="667256" data-mention="mykal451"><div class="wpforo-post-quote-author"><strong> Posted by: @mykal451 </strong></div><p>Pretty sure that's a Molex CLIK-Mate connector.</p></blockquote><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>MekCreate</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-pcb-connector-type/#post-667261</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-pcb-connector-type/#post-667260</link>
                        <pubDate>Thu, 03 Aug 2023 18:13:14 +0000</pubDate>
                        <description><![CDATA[Digging a little deeper the Molex &quot;series is 503-149, so the part number for the Nextruder connector plug is 5031492200. Posted by: @mykal451 Pretty sure that&#039;s a Molex CLIK-Mate connector.]]></description>
                        <content:encoded><![CDATA[<p>Digging a little deeper the Molex "series is 503-149, so the part number for the Nextruder connector plug is <a title="5031492200" href="https://www.digikey.com/en/products/detail/molex/5031492200/5254625?s=N4IgTCBcDaIKwAYDMBGALATjGBCQF0BfIA" target="_blank" rel="noopener">5031492200</a>.</p><blockquote data-userid="60405" data-postid="667256" data-mention="mykal451"><div class="wpforo-post-quote-author"><strong> Posted by: @mykal451 </strong></div><p>Pretty sure that's a Molex CLIK-Mate connector.</p></blockquote><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-pcb-connector-type/#post-667260</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-pcb-connector-type/#post-667256</link>
                        <pubDate>Thu, 03 Aug 2023 17:45:16 +0000</pubDate>
                        <description><![CDATA[Pretty sure that&#039;s a Molex CLIK-Mate connector.]]></description>
                        <content:encoded><![CDATA[<p>Pretty sure that's a Molex CLIK-Mate connector.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-pcb-connector-type/#post-667256</guid>
                        <title>MK4 PCB Connector type</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-pcb-connector-type/#post-666628</link>
                        <pubDate>Mon, 31 Jul 2023 08:09:12 +0000</pubDate>
                        <description><![CDATA[Hey.Do any of you know the connector that are used on the new MK4 PCB?I like to make a splitter so i can have a extruder more to pulling the filament.I had that on my MK3 and works great and...]]></description>
                        <content:encoded><![CDATA[<p>Hey.<br />Do any of you know the connector that are used on the new MK4 PCB?<br /><br /><a href="https://forum.prusa3d.com/wp-content/uploads/2023/07/IMG_20230715_135407a-scaled.jpg"><img class="alignnone size-medium wp-image-155351" src="https://forum.prusa3d.com/wp-content/uploads/2023/07/IMG_20230715_135407a-600x500.jpg" alt="" width="600" height="500" /></a><br /><br />I like to make a splitter so i can have a extruder more to pulling the filament.<br />I had that on my MK3 and works great and gives a better print, when the print head don't have to pull the filament.<br />Also because i have my filament in a dry box with ½meter of PTFE tube to the printer, so it's a bit hard to pull, so a extra extruder fix this problem on my MK3.<br /><br />But i can't fint anywhere what does connector are so i can order some and make a splitter.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-pcb-connector-type/#post-666628</guid>
