					                		MK4 Keeps homing the x-axis after y-axis check failed - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/</link>
                <lastBuildDate>Thu, 21 May 2026 14:44:45 +0000</lastBuildDate>
                        <title>RE: MK4 Keeps homing the x-axis after y-axis check failed</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-727309</link>
                        <pubDate>Mon, 18 Nov 2024 15:10:33 +0000</pubDate>
                        <description><![CDATA[For me it was the extruder main cable hitting the electronics box and causing too much resistance randomly. This got the X-Axis homing confused and made it automatically restart the printer ...]]></description>
                        <content:encoded><![CDATA[<p>For me it was the extruder main cable hitting the electronics box and causing too much resistance randomly. This got the X-Axis homing confused and made it automatically restart the printer sometimes.</p><p>This is caused by me putting the nylong-guide-filament in the wrong way, and it bending the part closest to the electronics box against it.</p><p>Also just for good measure, i let the little endstop screw next to the X-Axis motor stick out a bit further.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Herrcookiekiller</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-727309</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-711922</link>
                        <pubDate>Sat, 25 May 2024 08:52:14 +0000</pubDate>
                        <description><![CDATA[Hi everyone,I have exatly the same problem on my brand new MK4 (Firmware 6.0.1+14848). Two of your advices helped me solving it (for the moment...):Fully tightening of fan door screwavoiding...]]></description>
                        <content:encoded><![CDATA[<p>Hi everyone,</p><p>I have exatly the same problem on my brand new MK4 (Firmware 6.0.1+14848). <br />Two of your advices helped me solving it (for the moment...):</p><ul><li>Fully tightening of fan door screw</li><li>avoiding tension on the extruder/x-axis via the filament</li></ul><p>Now it's working properly. Thanks to all! 😍 </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>NoName</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-711922</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-697603</link>
                        <pubDate>Sun, 04 Feb 2024 16:29:39 +0000</pubDate>
                        <description><![CDATA[Also check if the screw that holds the fan door is firmly tightened as if the door is too loose it surely has an impact:See also below &quot;X/Y Axes&quot;]]></description>
                        <content:encoded><![CDATA[<p>Also check if the screw that holds the fan door is firmly tightened as if the door is too loose it surely has an impact:<br />See also https://help.prusa3d.com/article/selftest-failed-mk4_417808#troubleshooting  below "X/Y Axes"</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>tomatis</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-697603</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-697329</link>
                        <pubDate>Fri, 02 Feb 2024 15:30:48 +0000</pubDate>
                        <description><![CDATA[Update, it detects force from filament and thinks it is crash. I have own filament holders with cheap bearings, need to change them for smoother rooling.]]></description>
                        <content:encoded><![CDATA[<p>Update, it detects force from filament and thinks it is crash. I have own filament holders with cheap bearings, need to change them for smoother rooling.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>IAmNessuno</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-697329</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-696935</link>
                        <pubDate>Wed, 31 Jan 2024 09:35:23 +0000</pubDate>
                        <description><![CDATA[Same here. Before every print it detects crash and starts bashing, but after bashing ends it will allways start printing. No error or canceled print.It begins after 5.0.0 firmware update.]]></description>
                        <content:encoded><![CDATA[<p>Same here. Before every print it detects crash and starts bashing, but after bashing ends it will allways start printing. No error or canceled print.</p><p>It begins after 5.0.0 firmware update.</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-696935</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-696302</link>
                        <pubDate>Fri, 26 Jan 2024 20:51:49 +0000</pubDate>
                        <description><![CDATA[Definitely seems that tightening the 3 x-axis motor mount bolts has helped. Will see if it continues.]]></description>
                        <content:encoded><![CDATA[<p>Definitely seems that tightening the 3 x-axis motor mount bolts has helped. Will see if it continues.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>RickM</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-696302</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-695801</link>
                        <pubDate>Wed, 24 Jan 2024 02:31:25 +0000</pubDate>
                        <description><![CDATA[I don&#039;t know how it resolved itself, but I did an XY calibration a few times then a FULL calibration. No bashing since!]]></description>
                        <content:encoded><![CDATA[<p>I don't know how it resolved itself, but I did an XY calibration a few times then a FULL calibration. No bashing since!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Teakdamar</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-695801</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-695783</link>
                        <pubDate>Tue, 23 Jan 2024 21:44:15 +0000</pubDate>
                        <description><![CDATA[Same issue occurs for us.  Sometimes works, sometimes x-axis bashes over and over then works, or fails, or says crash detected.  Haven&#039;t figured a solution yet.]]></description>
                        <content:encoded><![CDATA[<p>Same issue occurs for us.  Sometimes works, sometimes x-axis bashes over and over then works, or fails, or says crash detected.  Haven't figured a solution yet.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-695783</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-694989</link>
                        <pubDate>Thu, 18 Jan 2024 14:42:27 +0000</pubDate>
                        <description><![CDATA[5.1.2 MK4 (ObXidian 0.4)In the past three days, nearly every print has begun with a homing of the X-Axis, where it crashes over and over into the left side, then accepts the new value and pr...]]></description>
                        <content:encoded><![CDATA[<p>5.1.2 MK4 (ObXidian 0.4)<br /><br />In the past three days, nearly every print has begun with a homing of the X-Axis, where it crashes over and over into the left side, then accepts the new value and prints like normal. Does not matter if the print is started with the control panel or with PrusaConnect.</p><p>I have been on the latest firmware for some time now, and am not sure why this would start now. It happened with the end of a roll of filament and now with a fresh roll as well, mounted on the stand sent with the machine.<br /><br />I'm very close to trying a factory reset, or just going through the full calibration wizard... I already tried just calibrating X &amp; Y under the control menu.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-694989</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-694856</link>
                        <pubDate>Wed, 17 Jan 2024 17:30:55 +0000</pubDate>
                        <description><![CDATA[Firmware 5.1.2 MK4Also encountered this issue.  tried a couple times, reset, same result.  Was printing from Prusa Link.  Shows crash detected with x and y with green checks, banging on left...]]></description>
                        <content:encoded><![CDATA[<p>Firmware 5.1.2 MK4</p><p>Also encountered this issue.  tried a couple times, reset, same result.  Was printing from Prusa Link.  Shows crash detected with x and y with green checks, banging on left side.  No visible obstructions, tube not strained.</p><p>I then printed from control panel and print started</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>tsetse fly</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/mk4-keeps-homing-the-x-axis-after-y-axis-check-failed/#post-694856</guid>
