MK4 belt sizes
Does anyone have the lengths of the x-axis and y-axis Gates 2GT belts for the MK4 handy? Apologies if this question has been asked.
thanks!
RE: MK4 belt sizes
Same question.
Cannot find documentation, and can't disassemble printer this week (probably next week too).
I can only see Mini/Mini+ and MK3 belts in the spare parts/accessories webshop with the explicit warning that MK4 is not compatible.
There's one non-prusa shop result from google search for "prusa mk4 replacement belt" but without any length information - levendigs [dot] com, not sure if that place is reliable or not.
RE: MK4 belt sizes
I would obtain a longer length of 6mm wide 2GT Belt, and cut it to the required length on assembly
I bought 5 meters length last time, so that I would have extra for future use.
RE: MK4 belt sizes
850mm
RE: MK4 belt sizes
X is 850mm, Y is 650mm.
RE: MK4 belt sizes
I've just measured my Mk4 as I had a problem with it being too loose and it's 632mm. It's very loose so something has gone wrong and I'm not sure what at the moment.
