Is there a way to power a 40mm 5V fan with the PSU?
VJ
 VJ
(@vj)
As title says, I'm building an enclosure for my Mk4, I'd like to keep the PSU in the enclosure, but separated from the printer by a different compartment and I was thinking I'd have a 40mm fan supplying fresh air from outside the enclosure into the compartment to help keep the PSU cool. So I was wondering, other than plugging the fan to a wall outlet, would there be a way to power it via the PSU? How about by using a relay or the Printer control board?
Any ideas would be awesome!
p.s. I'm not using the Prusa enclosure, building one from scratch due to space limits
This topic was modified 2 years temu by VJ
Opublikowany : 28/07/2024 2:31 pm
Eef
 Eef
(@eef)
Yes, look for: buck converter (alieexpress or amazon). 24 volt -> 5 volt
This post was modified 2 years temu by Eef
Opublikowany : 28/07/2024 9:41 pm
VJ
 VJ
(@vj)
RE: Is there a way to power a 40mm 5V fan with the PSU?
Oh nice, and how would I wire it up? use the same plugs on the PSU for the heaters? Would the converter turn on only when the printer is on?
Opublikowany : 29/07/2024 3:05 am
Artur5
(@artur5)
Why a 5V fan ?..  Even if you have one of these already, I think it's easier to purchase a 24V fan and connect it directly to the 24V outlets of the PSU.
Opublikowany : 29/07/2024 1:01 pm
VJ
 VJ
(@vj)
in that case, would the fan be going at full speed at all times?
Opublikowany : 29/07/2024 1:07 pm
Eef
 Eef
(@eef)
Posted by: @vj
An option is to connect to the output of the PSU (or input same wires on the board). That will have continu 24 Volt as long printer is on.
I would suggest another approach. I suppose you have already the 5V fan?
- find yourself on ordinary USB (old smartphone charger, etcetera, anything with 5V goes).
- buy a W1209 thermostat https://www.amazon.com/w1209/s?k=w1209 (attention choose the correct voltage!)
- connect the power wires of the charger to the W1209 + to the relay on the W1209 + fan.
And you have a perfect solution. Mine is set to about 27 degrees Celsius. As soon this temp is reached the fan runs as long it is needed.
Opublikowany : 29/07/2024 9:26 pm
