					                		filament sensor not connected check wiring - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/filament-sensor-not-connected-check-wiring/</link>
                <lastBuildDate>Thu, 18 Jun 2026 01:42:32 +0000</lastBuildDate>
                        <title>RE: filament sensor not connected check wiring</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/filament-sensor-not-connected-check-wiring/#post-765531</link>
                        <pubDate>Thu, 25 Sep 2025 13:26:25 +0000</pubDate>
                        <description><![CDATA[Same sequence of events (clogged nozzle into side filament sensor not turning on), same error message (&quot;filament sensor not connected, check wiring.&quot;), different printer (Core One).Mechanism...]]></description>
                        <content:encoded><![CDATA[<p>Same sequence of events (clogged nozzle into side filament sensor not turning on), same error message ("filament sensor not connected, check wiring."), different printer (Core One).<br />Mechanism also moves free.<br /><br />Did you ever find a solution ?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Nagasadri</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/filament-sensor-not-connected-check-wiring/#post-765531</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/filament-sensor-not-connected-check-wiring/#post-659987</link>
                        <pubDate>Mon, 12 Jun 2023 03:15:51 +0000</pubDate>
                        <description><![CDATA[It&#039;s not recognizeing sensor contact support through live chat probably faulty sensor]]></description>
                        <content:encoded><![CDATA[<p>It's not recognizeing sensor contact support through live chat probably faulty sensor </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Hello</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/filament-sensor-not-connected-check-wiring/#post-659987</guid>
                        <title>filament sensor not connected check wiring</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/filament-sensor-not-connected-check-wiring/#post-659974</link>
                        <pubDate>Mon, 12 Jun 2023 00:17:21 +0000</pubDate>
                        <description><![CDATA[after fixing a clogged hot end nozzle, I now get this following error and cannot turn on the filament sensor. I checked the wiring and everything seems to be ok. I can see the little mechani...]]></description>
                        <content:encoded><![CDATA[<p>after fixing a clogged hot end nozzle, I now get this following error and cannot turn on the filament sensor. I checked the wiring and everything seems to be ok. I can see the little mechanism move when i put in the filament.</p><p>any ideas?</p>
<div id="wpfa-154008" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.prusa3d.com/wp-content/uploads/wpforo/default_attachments/1686529041-mk4_sensor_2023.jpg" target="_blank" title="mk4_sensor_2023.jpg"><i class="fas fa-paperclip"></i>&nbsp;mk4_sensor_2023.jpg</a></div>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>JeffL</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/filament-sensor-not-connected-check-wiring/#post-659974</guid>
