Default e-steps value deliberately set too low?
npburns224
(@npburns224-2)
(Disclaimer at bottom.)
Since assembling my MK4, I've noticed a fairly small, yet consistent amount visible and measurable under-extrusion across multiple filament brands and materials. Since the amount was very consistent, I decided to verify the default e-steps value with a real-world test for my particular printer by perfoming the following steps:
  1. Loaded a spool of PLA into the extruder.
  2. Made a mark on the filament 120mm from the top of the filament path.
  3. Heated the nozzle to 235C, well above the typical PLA print temperatures.
  4. Sent M92 to the printer and recorded the default e-steps value of E380.00.
  5. Sent G91 to the printer to place it in relative movement mode.
  6. Slowly extruded 100mm of filament using the following g-code: G1 E100 F50.
Once the filament stopped moving, I measured the distance from the top of the filament path to the mark I made. I found that the value was not 20mm as you would expect, but exactly 25mm. This of course means the extruder was only pulling 95% of the requested length of filament.
If I had calculated any other value, I likely would have added a corrective line to my start g-code and shrugged it off. However, the fact that I was getting exactly 95% of the requested movement stood out to me.
On my previous printer, the MK3S+, there was a line in the default start g-code that set the flow rate to 95%. Was it a coincidence that my e-steps measurements also equaled 95%? Does this mean Prusa is intentionally using the e-steps value to effectively adjust the flow rate to 95% at the firmware level on the MK4?
The default start g-code on the MK4 actually includes a line that sets the flow rate to 100%. If reducing the flow rate was the goal, why not just change it here? Why set the flow to 100%, then reduce the e-steps to produce a similar effect?
If setting the e-steps to 95% of the correct/true value was a deliberate move by Prusa, what would be their reasoning? How could this be a better solution than adjusting the flow rate through g-code as has been done for years?
While reducing the e-steps does effectively reduce the flow rate, it also affects other print moves like retractions/deretractions. Why would you intentionally have the extruder motor always move 5% less than requested?
Disclaimer: I've written this post under the assumption that the use of a smaller e-steps value was deliberate, so forgive me if this is not the case. I just found the coincidence between my measurements and what Prusa has done with other printers to be a bit suspicious. After coming across a post on r/Prusa3D where a commenter also mentions calculating the same values I did, I thought I'd make a post here and see if others have noticed the same thing with their MK4s.
Posted : 23/08/2023 3:24 am
