					                		Artifacts and blurry surfaces - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/artifacts-and-blurry-surfaces/</link>
                <lastBuildDate>Sun, 14 Jun 2026 01:15:57 +0000</lastBuildDate>
                        <title>RE: Artifacts and blurry surfaces</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/artifacts-and-blurry-surfaces/#post-691202</link>
                        <pubDate>Tue, 26 Dec 2023 10:37:47 +0000</pubDate>
                        <description><![CDATA[I found out the issue. I haven&#039;t mount the thermal patch on the y motor. It has to be pressed between the motor and the frame.It appears to affect a lot the vibration of the printer and the ...]]></description>
                        <content:encoded><![CDATA[<p>I found out the issue. I haven't mount the thermal patch on the y motor. It has to be pressed between the motor and the frame.</p><p>It appears to affect a lot the vibration of the printer and the input shaping seems to be calibrate with this thermal patch correctly mounted.</p><p>Here a picture with and without the y motor thermal patch:</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/12/f729c09d-20231225_234650.jpg"><img class="alignnone size-medium wp-image-161575" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/12/f729c09d-20231225_234650-600x500.jpg" alt="" width="600" height="500" /></a></p><p>I hope this will help somebody. The thermal patch can age and change frequencies affecting the input shaping.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Djodjoke</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/artifacts-and-blurry-surfaces/#post-691202</guid>
                        <title>Artifacts and blurry surfaces</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/artifacts-and-blurry-surfaces/#post-690517</link>
                        <pubDate>Wed, 20 Dec 2023 17:09:34 +0000</pubDate>
                        <description><![CDATA[Hi everyone,I notice some strange artefacts and kind of blurry faces when printing with blend filament on my Mk4. It&#039;s seems that it&#039;s not noticeable with more matte filament.I print the sam...]]></description>
                        <content:encoded><![CDATA[<p>Hi everyone,</p><p>I notice some strange artefacts and kind of blurry faces when printing with blend filament on my Mk4. It's seems that it's not noticeable with more matte filament.</p><p>I print the same test part on my Mini to see if this occurs top, and it's not. Both printer use Input Shaper and latest firmware update (5.1.2). Here a picture:</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/12/6dcfacaf-20231220_174121-scaled.jpg"><img class="alignnone size-medium wp-image-161419" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/12/6dcfacaf-20231220_174121-600x500.jpg" alt="" width="600" height="500" /></a></p><p>I can't see any vfa on the Mk4 prints, but you'll notice some (If you have good eyes ;)) on the Mini, which is normal.</p><p>I don't think it's a motor problem. I check belt tension and it's alright. Maybe a bearing problem ?</p><p>If someone has an idea, I take it ! :)</p><p>Best</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/artifacts-and-blurry-surfaces/#post-690517</guid>
