					                		Two MK4 kits, different results - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/</link>
                <lastBuildDate>Thu, 11 Jun 2026 10:59:17 +0000</lastBuildDate>
                        <title>RE: Two MK4 kits, different results</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-687226</link>
                        <pubDate>Fri, 01 Dec 2023 19:07:54 +0000</pubDate>
                        <description><![CDATA[You need to factor in which is correct if you have two, logically you should have three with voting to establish correct reading and a warning for the minority report.]]></description>
                        <content:encoded><![CDATA[<p>You need to factor in which is correct if you have two, logically you should have three with voting to establish correct reading and a warning for the minority report.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>JP Guitars</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-687226</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-687201</link>
                        <pubDate>Fri, 01 Dec 2023 17:20:24 +0000</pubDate>
                        <description><![CDATA[Posted by: @trilithon
I have often wondered what the cost would be to add a second thermistor and input on the system to have a double check of sorts to validate the accuracy of the prima...]]></description>
<blockquote data-userid="532629" data-postid="687193" data-mention="trilithon">
<div class="wpforo-post-quote-author"><strong> Posted by: @trilithon</strong></div>
<blockquote data-userid="540079" data-postid="687092" data-mention="brew">
<div class="wpforo-post-quote-author">I have often wondered what the cost would be to add a second thermistor and input on the system to have a double check of sorts to validate the accuracy of the primary thermistor.</div>
<p>That reminded me of the quote from the movie Enemy of the State "But who will monitor the monitors"</p>
<p>Having a second thermistor would definitely be a good idea. However, like any other sensor on the printer it would be an added cost that shouldn't be needed unless it was a common issue. Which in my opinion fixing the bad sensor issue in the first place should be the way to go. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Brew</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-687201</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-687193</link>
                        <pubDate>Fri, 01 Dec 2023 16:55:26 +0000</pubDate>
                        <description><![CDATA[Posted by: @brew Good to hear. Looking forward to hearing how the new one works. Interesting that the bad one passed the tests. Guess it was only slightly faulty. My assumption is that the s...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="540079" data-postid="687092" data-mention="brew"><div class="wpforo-post-quote-author"><strong> Posted by: @brew </strong></div><p>Good to hear. Looking forward to hearing how the new one works. Interesting that the bad one passed the tests. Guess it was only slightly faulty. </p></blockquote><p>My assumption is that the self test just tests to see if the heater heats up and the thermistor detects it. What value the thermistor sends in this case is erroneous. It is reading 30-40c too low. I have often wondered what the cost would be to add a second thermistor and input on the system to have a double check of sorts to validate the accuracy of the primary thermistor. Another layer of safety too, I mean, what if it have been way off and overheated the hotend?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Trilithon</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-687193</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-687092</link>
                        <pubDate>Fri, 01 Dec 2023 00:58:43 +0000</pubDate>
                        <description><![CDATA[Good to hear. Looking forward to hearing how the new one works. Interesting that the bad one passed the tests. Guess it was only slightly faulty.]]></description>
                        <content:encoded><![CDATA[<p>Good to hear. Looking forward to hearing how the new one works. Interesting that the bad one passed the tests. Guess it was only slightly faulty. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-687092</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-687090</link>
                        <pubDate>Fri, 01 Dec 2023 00:51:53 +0000</pubDate>
                        <description><![CDATA[I swapped the thermistors between the printers. The printer that was printing perfect started stringing horribly, and the bad printer printed great! So the problem followed the thermistor.Du...]]></description>
                        <content:encoded><![CDATA[<p>I swapped the thermistors between the printers. The printer that was printing perfect started stringing horribly, and the bad printer printed great! So the problem followed the thermistor.</p><p>Dunno why I didn't think to swap them earlier, duh.</p><p>Thanks for the help and suggestions!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-687090</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-687015</link>
                        <pubDate>Thu, 30 Nov 2023 18:06:25 +0000</pubDate>
                        <description><![CDATA[Posted by: @trilithon Chatted with Prusa support, they are sending a new thermistor. Thats good]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="532629" data-postid="687010" data-mention="trilithon"><div class="wpforo-post-quote-author"><strong> Posted by: @trilithon </strong></div><p>Chatted with Prusa support, they are sending a new thermistor. </p></blockquote><p>Thats good</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Hello</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-687015</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-687010</link>
                        <pubDate>Thu, 30 Nov 2023 17:51:02 +0000</pubDate>
                        <description><![CDATA[Chatted with Prusa support, they are sending a new thermistor.]]></description>
                        <content:encoded><![CDATA[<p>Chatted with Prusa support, they are sending a new thermistor. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-687010</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-686996</link>
                        <pubDate>Thu, 30 Nov 2023 16:10:26 +0000</pubDate>
                        <description><![CDATA[They do have some in stock. I have one arriving tomorrow that they just sent. Hopefully it&#039;s not one of the faulty ones that they&#039;re supposed to have.]]></description>
                        <content:encoded><![CDATA[<p>They do have some in stock. I have one arriving tomorrow that they just sent. Hopefully it's not one of the faulty ones that they're supposed to have. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-686996</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-686886</link>
                        <pubDate>Thu, 30 Nov 2023 06:01:43 +0000</pubDate>
                        <description><![CDATA[If you contact prusa support they should send you a new one]]></description>
                        <content:encoded><![CDATA[<p>If you contact prusa support they should send you a new one </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-686886</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-686881</link>
                        <pubDate>Thu, 30 Nov 2023 04:58:35 +0000</pubDate>
                        <description><![CDATA[I have a MK4 kit and a MK3 -&gt;Mk4.  They were shipped about 5 months apart.  With Input shaping on, one prints matte and the other one glossy.  I reported it and was told that they have a ...]]></description>
                        <content:encoded><![CDATA[<p>I have a MK4 kit and a MK3 -&gt;Mk4.  They were shipped about 5 months apart.  With Input shaping on, one prints matte and the other one glossy.  I reported it and was told that they have a bad bunch of hot end thermistors.  They can't send me a new one because they don't have any "good"  ones to send.  The glossy one with IS is apparently the bad one and the one I prefer.  </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Cary</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/two-mk4-kits-different-results/#post-686881</guid>
