Platr Screen - Enlarge Suggestion Screen so words can be better seen and recover that screen
eager
(@eager)
I'm a total newbie. Total. I watched a YT videos for beginners and they suggest how to place an object on its face.
I then get suggestions in the bottom right of the screen but they aren't easy (for me) to see (and share).
I tried Ctrl + to enlarge the screen but that's not working. How do I enlarge those suggestion words?
Relate dot that if I click X to remove the suggestions how can I recover them?
I tried Ctrl + X but that doesn't work.
Thank you.
Napsal : 07/09/2024 9:31 pm
It's not entirely clear where you are having problems:
- if the difficulty is with the LED screen on the printer itself then propping up a an iPad or tablet in front of the screen and using the camera to enlarge the screen might help.
- if you are having trouble with the slicer where it does help to have a wide view meaning some of the print is small then most graphical operating systems offer a 'magnifying glass' visual aid that can be moved around the screen to help; in some cases it may just need to be enabled, in other downloaded as a plug-in.
An alternative is to use a larger screen - this is expensive if it's only needed occasionally but in this case you probly have a television screen far larger than your monitor and most can be connected to a computer as an auxiliary.
Napsal : 08/09/2024 7:05 am
JP Guitars
(@jp-guitars)
RE: Platr Screen - Enlarge Suggestion Screen so words can be better seen and recover that screen
Also if you are talking about the hints in Prusa Slicer, to the right of the text there are two icons. The one on the left of those two is a link to a web page that explains the hint in more detail. As that will be in a browser it should be easier to read
Napsal : 08/09/2024 8:32 am
