Which (if any) issues experienced….. Poll is created on Apr 26, 2023
MK4 Current Owners - Issues? [POLL]
Seite 13 / 15
TJH
 TJH
(@tjh)
RE: MK4 Current Owners - Issues? [POLL]
My MK4 kit overall works fine (apart from known prusalink/octoprint current constraints), except ...
My first layer consistency (PETG on satin bed) has been sketchy. I had a couple of instances where a strand of PETG fooled the printer into air-printing and a number of instances of in-sufficient squish on the first layer. My bed is pretty clean, but it's not brand new -- might be my setup, but I think there are still some underlying issues.
I am using firmware 5.0.0. Seems to me that the pre-heat temp of PET should be higher than 170 if you want to melt the filament enough for the sensing to work.
I assume that things will get better over time. I'm happy to be rid of the pinda.
Veröffentlicht : 05/10/2023 12:27 am
newradius
(@newradius)
Mitglied
My first layer is never perfect. Load cell sensor replacement on the way.
Veröffentlicht : 24/10/2023 1:25 pm
Doc
 Doc
(@doc-3)
occasionally I have experienced that a print will not start due to a nozzle cleaning error. Typically I have resolved this by scraping the PEI sheet where the nozzle cleaning was done. There appears to be bits of filament at that spot that once cleaned, will allow for nozzle cleaning to process without error.
The frustration with this issue is that the nozzle cleaning process deposits those bits of filament and causes the cleaning process to fail.
Also no issues with the prints after this cleaning process failed. I am not convinced that the filament cleaning process, as currently implemented, is necessary.
Veröffentlicht : 24/10/2023 3:23 pm
SweetRide
(@sweetride)
So far liking the printer.
PETG not sticking to the textured build plate has been a thing.
I am having a hard time dialing in the Y belt tension. I get the homing failure and hate the pounding the stop to recalibrate or whatever. I would like to fixt that.
Veröffentlicht : 24/10/2023 3:36 pm
Bullseye3d
(@bullseye3d)
Posted by: @sweetride
Bedwise, make sure to clean it really good with 90%+ alcohol (I only use 99%)
Try to increase bed temp (what temp are you setting it to?)
Veröffentlicht : 24/10/2023 3:43 pm
the-powl
(@the-powl)
Try one of these and tell us if it worked out.
https://www.printables.com/de/model/465185-prusa-mk4-fan-draft-shroud
https://www.printables.com/de/model/585199-prusa-mk4-fan-cover
https://www.printables.com/de/model/621216-prusa-mk4-fan-cover
It reduces the air turbulence on the bed, that's induced by the heatbreak fan
Veröffentlicht : 24/10/2023 3:47 pm
ChiTownGuy
(@chitownguy)
I am using a fan shroud (the 3rd one listed) and a glue sticking the bed before printing.
I use one side for glue stick prints and one side for prints without a glue coating.
Veröffentlicht : 24/10/2023 3:59 pm
Tom Horsley
(@tom-horsley)
The only issue I have is with PrusaLink. Once in a while (not very often), I'll use "upload and print" from Prusa Slicer and it will do the whole upload then say "Internal server error" instead of starting the print. I have no idea what triggers this, but I usually just reset the MK4 to clear out any cobwebs and it works fine on the next attempt.
Veröffentlicht : 24/10/2023 8:04 pm
luc.e
(@luc-e)
Same here, a lot of stringies (PETG) not tested other filament yet. Tried changing retraction, temperature... to no avail. A bit disappointed as my MK3S+ worked flawless.
Veröffentlicht : 14/11/2023 9:23 pm
the-powl
(@the-powl)
Posted by: @tom-horsley
Just a quicktip: make sure you're in the main menu. It you're still in some status screen or the finish-screen of the last print, it'll result in that internal server error.
Veröffentlicht : 14/11/2023 9:25 pm
Crab
 Crab
(@crab)
@sweetride:  Many users report the textured sheet (I have one) has a film from the factory.. Clean well with soap and water.. that will dissolve some stuff that alcohol won't.. in fact I generally find dish soap and hot water better than alcohol for cleaning. You might mildly scrub with a plastic dish sponge.. That should help adhesion. You might try increasing the bed temp 5 deg as well. You can get an IR thermometer to see if your bed is getting close to the proper temp. It won't be bang on what you dial because the sensor isn't at the top, but should be within 5-10 degrees everywhere.
Veröffentlicht : 14/11/2023 10:22 pm
kengineer
(@kengineer)
Currently no available hard nozzles, no available nozzle assembly, no available nylon print plate. nozzle marking the smooth print sheet, MMU paid and promised months ago not shipped. Still working on it.
new Prusa motto:
Way over promise way under deliver. Ship whenever some of the bugs are reduced, software updates to follow.
Print on tee shirts and hand out.
Veröffentlicht : 15/11/2023 3:16 am
MileHigh3Der
(@milehigh3der)
I think the printing on T-shirts accessory is delayed. ..
Veröffentlicht : 15/11/2023 3:38 am
Mikyner
(@mikyner)
Mitglied
My MK4 squeaks when printing PETG, some PETG squeaks less, some more, but it always squeaks. No one from support has been able to advise me how to fix this problem until today. 😢
I was deciding between Bambulab X1C and Prusa MK4. MK4 I chose because it is less noisy compared to X1C, but wouldn't bambulab fans be better than squeaking..?
Video: https://1drv.ms/v/s!AkoWjpZFyViRgfwe-gnQZJiFOaMXjw?e=6oPxtR
Veröffentlicht : 16/11/2023 10:17 pm
JeffL
(@jeffl)
I loathe printing with my Mk4... i rarely good get results. I have to rely on my MK3.
Veröffentlicht : 16/11/2023 10:55 pm
luc.e
(@luc-e)
For PETG I lower the temperature to 220 both hot end and bed, that way I get very satisfying results similar to what I had with my MK3S+. Not sure if it is the temp sensor measuring wrong or the AD conversion in the firmware or I just have a broken sensor. As I can't measure the hot end temperature I'm in the blind here. I did read others had to do the same to get less stringing and blobs so it might be something that can be corrected in firmware.
Veröffentlicht : 17/11/2023 11:08 am
the-powl
(@the-powl)
I measured the hotend temperature and one of the sensors I got sent by them was 15°C off (hotter). They apparently have problems with the complete batch of sensors so it's quite possible that your sensor is somewhat malfunctioning. But you can just set the temp lower and you're fine.
Veröffentlicht : 17/11/2023 11:22 am
Mitglied
Have you contacted support?  Mine works superior to my Mk3S+ or prior Mk3.  Maybe they can help.
Posted by: @jeffl
Veröffentlicht : 17/11/2023 11:33 am
Mitglied
Have you reported the problem to support?  They might replace it.
Posted by: @the-powl
Veröffentlicht : 17/11/2023 11:35 am
luc.e
(@luc-e)
Thank you cwbullet for your reply. Looks like I'm in that situation. I'll get it to support like you suggest.
Veröffentlicht : 17/11/2023 2:03 pm
Seite 13 / 15
