Jak vyndat zalomený filament z trysky MK4
Stalo se mě, že se mě zasekl tisk byla závada na filamenu na délce 10cm byl zesílený na 2mm. Následně se zlomil u těsně u trubičky trysky. A teď jak ho vyndat? Ohřát a vytlačit nešlo vyndání a ohřátí trysky nepomohlo, naopak se oddělila trubky od trysky. Pak už trubička v trysce nedrží. Co stím?
Respondido : 17/04/2024 6:55 am
You've posted this in the English forum.
Respondido : 17/04/2024 8:03 am
Topic starter
answered:
RE: How to remove a kinked filament from a MK4 nozzle
It happened to me that the print got stuck. There was a problem with the filament on the length of 10 cm. It was reinforced to 2 mm. Subsequently, it broke near the nozzle tube. And now how to take it out? It was not possible to heat and squeeze out and heating the nozzle did not help, on the contrary, the pipe separated from the nozzle. Then the tube no longer holds in the nozzle. What with this?
Respondido : 17/04/2024 2:43 pm
