					                		Clogged Extruder and broken filament? - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/clogged-extruder-and-broken-filament/</link>
                <lastBuildDate>Sat, 06 Jun 2026 01:55:47 +0000</lastBuildDate>
                        <title>RE: Clogged Extruder and broken filament?</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/clogged-extruder-and-broken-filament/#post-670124</link>
                        <pubDate>Mon, 21 Aug 2023 20:30:19 +0000</pubDate>
                        <description><![CDATA[My MK4 is also having problems. I got halfway through a 8hr print when filament just stopped coming out. I tried to purge but the gears just kept slipping along the filament and did the same...]]></description>
                        <content:encoded><![CDATA[<p>My MK4 is also having problems. I got halfway through a 8hr print when filament just stopped coming out. I tried to purge but the gears just kept slipping along the filament and did the same thing when trying to unload. I had to open the side to relieve some pressure and then use pliers to pull it up and out. It morphed a bit from the gears trying to push it down and made it a bit fatter where it was broke. I got a couple smaller prints out of it before it happened again. Except this time whatever is stuck is further past the gears. I tried heating the nozzle and sticking the acupuncture needle up it and that didn’t do anything. If I try to load filament and purge then the gears just slip along the filament again. I have no idea what to do.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Garrett Cannon</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/clogged-extruder-and-broken-filament/#post-670124</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/clogged-extruder-and-broken-filament/#post-668837</link>
                        <pubDate>Sun, 13 Aug 2023 20:31:51 +0000</pubDate>
                        <description><![CDATA[Just a heads-up: I have now extracted the tube and used an air-heater to make the broken filament fluid; this worked then to get the broken filament out. Now, apparently some filament is stu...]]></description>
                        <content:encoded><![CDATA[<p>Just a heads-up: I have now extracted the tube and used an air-heater to make the broken filament fluid; this worked then to get the broken filament out. Now, apparently some filament is stuck in the gear and I will remove it as good as possible ;)</p><p>I have no idea why Prusa switched from the ptfe-tube to a metal-tube all the way, but I would have preferred to be able to "split" the tube to make cleaning easier... ;)</p><p>(especially since you can not order yet the tube as replacement part at prusa ...)</p><p> </p><p>best regards, Hanno</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Rince</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/clogged-extruder-and-broken-filament/#post-668837</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/clogged-extruder-and-broken-filament/#post-667814</link>
                        <pubDate>Mon, 07 Aug 2023 17:39:34 +0000</pubDate>
                        <description><![CDATA[I have exactly the same problem with my brandnew MK4 with any 5 print with a brandnew Prusament.It start printing in the middle or at the end with no more filament extrusion and I found out,...]]></description>
                        <content:encoded><![CDATA[<p>I have exactly the same problem with my brandnew MK4 with any 5 print with a brandnew Prusament.<br />It start printing in the middle or at the end with no more filament extrusion and I found out, that it always breaks in the hotend or at the top of the hotende.<br />Also the extroder starts with a loud cracking sound.<br />I managed to get the filament out at 280 degree with a loong 0.4mm needle (meant for such puposes) but after the thrird break, I can't get the filament out, it's stuck in the middle of the hotend and does not move in any direction.<br />Seem to be a problem with the MK4 or Prusa shipped faulty filament with the MK4. It is brandnew and storeed in the enclosure and I just started to use it.<br />Let me know if you could solve it and what the root cause was.<br />If I cant get it solved with a new hotende and new filament, I need to send the MK4 back.</p><blockquote data-userid="53692" data-postid="666812" data-mention="rince"><div class="wpforo-post-quote-author"><strong> Posted by: @rince </strong></div><p>Hi,</p><p> </p><p>I used some old PLA-filament to print the first parts of the upgrade of my (old) MK3 to MK4. after a while I saw that the printer was not printing anymore - no filament was put out.</p><p>looking to the nozzle (and taken it out of the extruder box) I saw that the filament was broken. I heated up the heater to 280°C and first tested with an acupuncture needle wether the nozzle is free - and it seems to be. But I wasn't able to take the filament out from above since there was no way to fetch it. then I tried to push it down with an inbus key but it wasn't able to push the filament (it stopped after ~1cm).</p><p>since currently I can not order a new nozzle from Prusa, what are my options? are there longer needles I can use to find the blocked part from down below and "push" it upwards? can/shall I move the heaterblock and hope that I can make the filament more fluid inide the tube?</p><p> </p></blockquote><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>heinzv</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/clogged-extruder-and-broken-filament/#post-667814</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/clogged-extruder-and-broken-filament/#post-666963</link>
                        <pubDate>Tue, 01 Aug 2023 22:51:19 +0000</pubDate>
                        <description><![CDATA[Heat the nozzle and remove it - see the nozzle change procedure.You should be able to push the residual filament through the wider path with another piece of filament, follow up with a cold ...]]></description>
                        <content:encoded><![CDATA[<p>Heat the nozzle and remove it - see the nozzle change procedure.</p><p>You should be able to push the residual filament through the wider path with another piece of filament, follow up with a cold pull.</p><p>Inspect the nozzle and decide whether to reinstall or replace it - then complete the change procedure and try again.</p><p>Brittle PLA is a symptom of water takeup - if left out in humid conditions for a long time it micro-cracks and can, sometimes, become unuseable but first try drying it and you may be able to restore it.</p><p>Cheerio,</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/clogged-extruder-and-broken-filament/#post-666963</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/clogged-extruder-and-broken-filament/#post-666841</link>
                        <pubDate>Tue, 01 Aug 2023 12:20:45 +0000</pubDate>
                        <description><![CDATA[Head to the nearest music store and buy a guitar string to use instead of the acupuncture needle.]]></description>
                        <content:encoded><![CDATA[<p>Head to the nearest music store and buy a guitar string to use instead of the acupuncture needle.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>haxxlinus</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/clogged-extruder-and-broken-filament/#post-666841</guid>
                        <title>Clogged Extruder and broken filament?</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/clogged-extruder-and-broken-filament/#post-666812</link>
                        <pubDate>Tue, 01 Aug 2023 10:15:57 +0000</pubDate>
                        <description><![CDATA[Hi, I used some old PLA-filament to print the first parts of the upgrade of my (old) MK3 to MK4. after a while I saw that the printer was not printing anymore - no filament was put out.looki...]]></description>
                        <content:encoded><![CDATA[<p>Hi,</p><p> </p><p>I used some old PLA-filament to print the first parts of the upgrade of my (old) MK3 to MK4. after a while I saw that the printer was not printing anymore - no filament was put out.</p><p>looking to the nozzle (and taken it out of the extruder box) I saw that the filament was broken. I heated up the heater to 280°C and first tested with an acupuncture needle wether the nozzle is free - and it seems to be. But I wasn't able to take the filament out from above since there was no way to fetch it. then I tried to push it down with an inbus key but it wasn't able to push the filament (it stopped after ~1cm).</p><p>since currently I can not order a new nozzle from Prusa, what are my options? are there longer needles I can use to find the blocked part from down below and "push" it upwards? can/shall I move the heaterblock and hope that I can make the filament more fluid inide the tube?</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/clogged-extruder-and-broken-filament/#post-666812</guid>
