Belt tension Y-axis - tightening causes it to change pitch
Oompyor
(@oompyor)
Your supposed to screw out one screw and then tighten the belt with another. Along with the sound app being quite useless although more functional on the y-axis, once you have found something that at least sounds like the strum from the video demonstration, when you then tighten the first screw it changes the pitch entirely, I can never get it correct no matter what I do once i secure it.
Also with the X-axis the mic is entirely useless, on a high end phone, it shows too high no matter if its too low or too high, and i strum quite gently or less gently. Its would be much better if they just uploaded a high end sound of how the pitch is supposed to sound, and go by that. I'm not entirely sure based on the audio from the video.
Meaning, I can never get the belt tension correct...
Wouldn't something like an item with a given weight and size, that you put on the top belt and when it touches the second belt its fine be much easier, or does that not work?
Napsal : 02/06/2025 8:56 pm
TiaGoyette
(@tiagoyette)
RE: Belt tension Y-axis - tightening causes it to change pitch
Yes, using a weight and checking for belt deflection is a valid mechanical solution used in real engineering.
Grow a Garden
Napsal : 05/11/2025 3:22 am
