Bed Bearing Bolts Loose
The bolts that hold the bed bearings, both sides, keep coming loose however much I tighten them, could this be down to the rubber insert under the bearing?
Posted : 14/01/2024 4:31 pm
RE: Bed Bearing Bolts Loose
I noticed mine were loose too, which caused Y axis calibration to fail. I didn't disassemble though, so no idea if this was due to wear of the rubber part.
Posted : 17/01/2024 12:16 am
I used some purple loctite on the threads when I assembled my kit. So far, so good. You can remove, loctite, and replace one at a time so you don't have to reposition everything.
Posted : 23/01/2024 3:55 am
