6.2.3 Firmware for Original Prusa MK4
Jan Kratochvíl
(@jan-kratochvil)
Membre Admin
Summary
  • Hotfix for the MMU overcurrent
  • Fixed returning to wrong Z position after pause
This is a stable release of firmware version 6.2.3 firmware for the Original Prusa MK4, MK4S, MK3.9, MK3.9S, MK3.5 & MK3.5S.
A recent supply change of a few electrical components has caused issues during the MMU power-on procedure due to the new components having different tolerances.
We have adjusted the MMU power-on procedure to accommodate this change. The current solution is a hotfix that introduces a small (~1s) delay when powering on the MMU. A more permanent solution will be released soon.
We would like to thank you, the community, for your efforts regarding this issue. Your observations and discoveries have made it much easier for us to locate the problem and focus more on how we could fix it.
When unpausing, the printer was not applying the MBL correction to the unpark move.
Release notes:  https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.2.3
Publié : 24/03/2025 2:44 pm
Vileam Healen
(@vileam-healen)
Membre
RE: 6.2.3 Firmware for Original Prusa MK4
The MMU overcurrent issue was definitely a head-scratcher, so it’s great to see a workaround in place while a more permanent fix is in the works. Also appreciate the Z position bug being addressed—was wondering why the nozzle wasn’t quite where it should be after a pause. Big shoutout to the community and devs for staying on top of it!
google baseball
Publié : 25/09/2025 3:38 am
