Random reboots?
I received my MK4 kit several weeks ago and have been running it non-stop with almost no problems. Early on I observed a reboot when I was plugging something else into same power strip as the printer. I assumed that I bumped the plug. I moved the printer to a different power strip. Many prints later I tried printing a model and it failed twice (rebooted) and I felt as if the Gcode were to blame. I deleted the Gcode and made many more successful prints but it has happened several times in the last two days with different models at different times into the print at different Z heights. I suspect either the supplied thumb drive, network corruption or overheating. I sliced a model wrote directly to the drive from my PC and am printing now. Does anyone have any insight into this problem?
RE: Random reboots?
Another reboot 40 minutes into a print that written directly to a new thumb drive.
RE: Random reboots?
Just started getting this issue myself. On 5.0.0 RC1 firmware. Fails in the same place every time for me, and I'd guess it's about 40 minutes in as well. Printer doesn't crash or anything, it just stops printing and restarts asking if I wanna print the most recent file on the USB. I sliced and moved it directly to the USB from my PC as well and also had the same failures when uploading the gcode through PrusaLink.
RE: Random reboots?
Just happened to me, even tho I’ve been printing non-stop for 5 days now since installing rc1.
the file was sent with prusa connect, rebooted at around 60/65%
RE: Random reboots?
Hello, Just happened to me tonight, after several months having no issues at all... already printed several times the same gcode, so I doubt a faulty file is the issue. Has anyone found a fix ? thanks in advance...
